Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Whisper belt how do I change the belt
  • Kenmore Master
  • 18,424 Answers
Get the belt to turn in Progressive Whisper belt
Make sure the roller is not jamed with carpet threds , remove bottom cover and clean dust balls and obstructions out see if ti resolves problem make sure it's unplugged when checking and install complete before applying power!
Feb 21, 2015 | Kenmore 25614 / 25615 Progressive Bagged...
How do I change the bag in a Kenmore Whispertone 300
Read the instructions.
My new replacement bags have the instructions right one one side of the bag itself. or if you have the book read the instructions.
Mine is a Kenmore Whisper tone but not 300 so I won't pass on my instructions but my bags fit different Whisper tone Vacs.
Feb 07, 2015 | Kenmore Vacuums
Hoover zen whisper multi cyclonic canister vacuum belt removal
just underdo the screws from the bottom of the hoover head (where the brush rotates from) I think from memory there are about 8 screws carefully price the plastic apart use a flat headed screwdriver as sometimes there are retaining clips and you should be able to access it hope this helps
Apr 05, 2014 | Hoover Zen Whisper Multi-Cyclonic Canister...
My Kenmore Progressive Whisper Belt canister vacuum is not "whispering." In fact, it makes excessive noise during operation - much more than the older Kenmore model that it replaced. I have replaced the...
Probably either bearings in the roller brush, a damaged fan blade, or the bearings in the motor. Take the roller brush off completely, and run the VAC without it. If it's much more silent, then the problem is with the bearings in the roller brush. If it's still noisy, then look closely at the fan that produces the suction, if you can. If you see any damaged blades, then you'll have to replace it. If it seems fine, then it's most likely bearings in the main motor that will have to be replaced. The bearings and the fan blade are NOT expensive parts, but the labor at a shop to change the main bearings would be kinda pricey.
Oct 18, 2013 | Kenmore Vacuums
(hover whisper cyclone)brush stopped rolling checked belt and looks fine what else can it be?
check other side from belt may be a little jam on the rollers on the oppsite side of the belt
Sep 27, 2012 | Vacuums
Canister powerhead brush does not seem to spin when the carpet level adjustment is on any level other than "high". Could it be something as simple as needing a new belt and is there a...
The belt is worn/stretched to the point that it cannot take the load on low level setting due to more resistance against the carpet and there is also no signifagant difference between the two belts except for expecting a longer belt life from the whisper belt. While it is apart make sure there is no hair or carpet strands in the rollers and around the belt pulleys
Jan 18, 2011 | Kenmore 25512/ 25513 Progressive Canister...
My Hoover Whisper Cyclonic is collecting the dirt but not taking it into the cylinder. The brushes were at one point starting and stoping due to the belt periodically turning,now the brushes are turning...
You need to change the belt once every year. It's a good idea to take it to your local vac shop and have it serviced once a year also. They can fix this for you. Your belt is worn out.
Jun 30, 2017 | Hoover U5753-900 WindTunnel Bagless...
Kenmore whisper tome model # 116
If this uses a cogged belt, it should not fall off unless it is the wrong one. Give me the whole model #, then I can look and see what you have. The number of the power head is needed.
May 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
