Question about Sony HVR-A1U Camcorder
Sony a1u hvr final cut pro capturing presets
I am trying to capture my HDV footage with fcpro 7 and set the presets to hdv and hdv firewire and fcpro is still not detecting the external device as being attached. Iunplugged and replugged in everything, shut down my computer, turned off and on the camera, unplugged everything again, and the system is still not recognizing the camera as being attached. I also tried a different firewire.
2 Suggested Answers
SOURCE: HVR-Z1E Capture problem
Hi George, Sounds like you and I are of the same level with this Cam and editing , would love to compare notes with you if you would care to drop me a line gemfilmsni@yahoo.co.uk
Pat
Posted on Jul 13, 2009
I can't initialize on FCP
If you are capturing HD, go into the menu > IN/OUT REC > i.LINK CONV and set it to off, and A/V->DV OUT to off. Go into FCP and go to the File Menu and select "easy setup". In the easy setup menu set the "Format" to "HDV" and set "Use" to HDV - 1080i60. Click "Setup". Now go to File > Log and Capture (command-8). You're now set to capture. Just queue your tape and hit "Capture Now" or set in and out points and capture "Clip".
If you want to capture SD footage, then on your Sony unit, go to the menu and set the i.LINK CONV to "on". In the easy setup menu you will want to set "Format" to "NTSC" and "Use" to DV-NTSC".
Sep 26, 2008 | Sony GV-HD700 HDV VCR
I am trying to digitize HDV footage using fcp 6.0.6 on an Intel imac with 2gb ram. Trying desperately to get my computer to recognize the Vixia HV 30 camera, but it will not. I have tried changing...
First, confirm what type of video is being output from the camera as HDV cameras can also ouput DV or can Downconvert HDV footage form the camera to DV even if the settings for recording were HDV.
The message is to double check and understand the menu settings within the camera.
Once done FCP will require an Easy Setup that matches the camera output.
If you shot and are indeed outputting HDV, start off with Easy Setup>HDV-Apple Intermediate Codec1080i60, assuming you a an NTSC user.
Mar 18, 2011 | Canon VIXIA HV30 DV Camcorder
Pat
Jun 06, 2009 | Sony HVR-Z1 Mini DV Digital Camcorder
My JVC GY-HD111E isn't located in final cut pro
Are you using HDV, make sure you set the signal to DV on the camera. Does it have a signal out option to switch from video to dv / firewire? Have you checked to see if it is supported? Also just keep trying, turn camera on and off, restart the computer with firewire connected then without. I had this problem with a deck and it randomly started working after my 5th try.
Mar 28, 2009 | JVC GY-HD111E Mini DV Digital Camcorder
HD footage stutters after captured in Final Cut Express HD 3.5.1
Did you capture as HDV? When you render is it ok? Some times it is best to capture as DV not HDV the quality will be as good (letter boxed) but it means fce is not having to decode the mpg4 compression of HDV in realtime. Can lead to a jolting due to extram RAM usage.
Mar 04, 2009 | Apple Final Cut Express HD for Mac
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
Jan 01, 2009 | Canon XH A1 Mini DV Digital Camcorder
Unable to
HHHhhhmmmm. I'd suggest the DV mode and if you camera has the option to output DV as letter box select this, as it is a faster version to edit with (due to compression of HDV). I don't know the camera but VTR is just the playing mode, so play the file you want while trying to connect. Is the signal coming from tape? If it is catured to the harddrive of the camera you will need to import not capture.
USB does not support video, USB2 maybe.
I
Jan 11, 2008 | JVC Everio GZ-HD7 Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Sony HVR-A1U Camcorder Logo
18 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
