Question about Sperry TopSider Sperry Top Sider Topsider Endurance for Men
How do you get the smell out of sperry top sider shoes
Top siders worn without socks shoes still good but have an odor how do i get the odor out
Tip
Natural ways to help with foot odor
Many of us have foot odor due to many reasons. A good breathable pair of shoes or sneakers and socks will help. But when your tootsies need extra help try these solutions:
Give your feet a nice soak in water with a bit of vinegar in it. Even a tablespoon of vinegar in 4 inches of water will do. Soak for 10-20 minutes then rinse off with water only.
Rub some natural oils such as aromatherapy oils on your feet before bed and wear socks over that so you won't ruin your sheets.
Give your feet a foot rub with some salts any salts scented or unscented will do. What you want is to scrub them so as to take off some dead skin then run with a good smelling oil or cream. If you don't have any creams use some baby petroleum jelly you can find in any dollar store.
Spray your feet with foot spray before wearing your shoes. Your shoes are very important if they smell so will your feet. It is hard to tell if they smell sometimes. Try the smell test on shoes after you have worn them. spray or disinfect if needed.
Always wash your feet well when taking showers or bath. No, they will not get clean cause the water is dripping on them, they need to be washed like the rest of the body.
Happy feet are also manicured feet go get a pedicure! Even guys get them. But make sure the place practices good hygiene and disinfects things for each customer.
Enjoy your good smelling pampered tootsies!
on Oct 17, 2013 | Health & Beauty
What is a natural way to remove foot odor from my shoes?
You can just put baking soda in your shoes. That stuff does a pretty good job of neutralizing a lot of odors.
Jan 16, 2013 | Health & Beauty
How can you get rit of the smell in your sperry
fill with baking soda and place in freezer. once the moisture and bacteria are gone they should smell better. consider washing insoles. allow to dry before replacing and try to keep the shoes dry to avoid oder
May 16, 2012 | Sperry TopSider Sperry Top Sider Topsider...
Need to replace the soles of my topsiders... where can I find a replacement kit?
I am unaware of a repair kit for these shoes. If you are looking for a kit, I would suggest you contact Vibram for information about this. They are at quabug.com
Aug 13, 2011 | Sperry TopSider Sperry Top Sider Topsider...
Well, I wear my men's UGG ascot slippers a lot. I do not wear socks with them when I do wear the shoes. After I wear them, I spray the UGG odor spray in the slippers to prevent lingering odor. However,...
The problem is the heat produced in the shoes. Since they are so warm many people's feet sweat in them making them smell, and the fur makes the smell stay. One suggestions would be to obviously wear socks, that's what I do with my uggs. If you would rather not wear socks then you can try washing them, but you can only do it by hand because the washer may ruin them. Be careful tho because they are easily ripped when wet. If that doesn't help enough then get odor eaters for shoes and use them when you aren't wearing them. If possible many people have started to replace the inserts in their uggs. Click here to see a website that sells these inserts and click here for a website that sells odor eaters.
Feb 16, 2011 | UGG Australia Ascot Slipper Shoes
The soles of both of my Topsiders have split across at the ball of the food down to the leather part of the sole of the shoe.
HI
I THINK THAT NOT A PROBLEM WE CAN REPLCE THE SOLE F YOUR SHOES . WHEN DID YOU BUY YOUR SHOES IS IT STILL IN WARRANTY IF YES THEN APPROACH YOUR AUTHORIZED DEALER AND GET THE REPLACEMENT IF NOT , TRY APPROACHING ANY DEALER WHO DEALS WITH YOUR SHOES AND GET THE WORK DONE IT WILL BE CHEAP ONLY . IF YOU FURTHER NEED ANY HELP PLEASE CONTACT ME THANK YOU
IF MY ANSWER WAS HELPFUL PLS VOTE FOR ME :)
Dec 17, 2010 | Sperry TopSider Sperry Top-Sider Gold Cup...
New fuel pump installed. Works but will not supply motor with fuel. Motor runs with gas poured in carb. where is th fuel pump fuse and relay?
under the hood on fire wall. these blazers had alot of problems with the sider injection system locatede under intake pliunm; good luck.
Oct 13, 2009 | 1997 GMC Jimmy
Changing the coordinates of the autostar for meade etx 125
What are you using as a reference for "LST time"? I assume you're aware
that stands for "Local Sidereal Time", and not Local Standard Time; some
folks have confused the two. Do you have another method to calculate
Sidereal time for your location?
When you set Date and Time in the Setup menu, you need to use the time
from the "clock on the wall" without any mental adjustments for Daylight
Saving or Time Zone; those settings are made elsewhere. From your
description of the problem, it sounds like you have a time offset,
especially if your Site location values are fairly accurate.
Whether you use Zip Code or City sometimes depends on where you live
with respect to a particular city. If you live several miles from the
nearest city, Zip Code may be best .
Dec 12, 2008 | Meade ETX-125PE (500 x 127mm) Telescope
Sperry TopSider Sperry Top Sider Topsider Endurance for Men Logo
52 people viewed this question
Top Sperry TopSider Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Sperry TopSider Clothing Accessory Expert? Answer questions, earn points and help others
