Question about Kodak Office Equipment & Supplies
Fan speed varies - Ektagraphic IIIb
I'm saying this based on the sound... the fan sounds loud, then soft, then loud, then soft... about 1 second for each cycle. Do I need to lubricate the fan somehow?
    President:
  • Kodak Master
  • 412 Answers
My suspicion is that the fan belt has fatigued and stretched. When this happens, the excess belt diameter "slaps" and causes fan speed variations. My recommendation is if you are opening up the projector to replace the fan belt, replace the mechanism belt, as well. While I can't say absolutely any more, but parts for Kodak projectors have been available from: www.micro-tools.com. You can contact them to verify parts availability. Good Luck !!
Jim
Posted on Feb 11, 2015
Fan is extremely loud and sounds like a jet engine
there are 3 speeds for that fan sounds like its at the highest speed might be a relay problem or a temp sensor problem. and that fan isn't 800.00 dollars someone is kidding you call a parts place yourself. although there should be no reason to replace it this time
Apr 15, 2013 | Chrysler 2003 PT Cruiser GT
I just replaced th fan clutch and water pump on my 2004 durango 4.7 and when i step on the gas now tach needle jumps up like crazy and the fan sounds like a jet and the engine seems slugish
The fan clutch may be different from the original, they use oil inside to vary the speed most of the time. Some are more affected by air temp than others.
As far as performance goes, is the check engine light on ?
Jul 04, 2012 | 2004 Dodge Durango
What causes the loud sound of my laptop air vent?
It could be your vent fan speeding up to vent more air out of your laptop as it gets hotter. Two things you might want to consider:
1. Buy a laptop cooler
2. Clean out your laptop vents and fans with a can of compressed air.
May 14, 2012 | Computers & Internet
E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
Hello
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
Sep 12, 2011 | Uniden TRU9485 Cordless Phone
The Sound used to increase over a few hours. NOW the machine starts up REVED.... When you turn it on after letting it cool, it's silent until you start Windows, and the noise picks up a little. You...
Hello there! Noisy Sounds can be much frightening, but if you could determine from where the sound is coming on you will get the solution, the sound makers inside a pc are mostly fans, and what type of sound you are actually hearing, rattling sounds means some wires touching up the C.P.U Cooler fan, another one could be a loose fan on the SMPS. Solution to this is to Check all the Fans Do so by
1. Remove the Cabinet cover on one side and Start the machine and try to see and determine what actually is making the noise, rattling sound could be a wire or something touching the fan, if its okay, then listen for the SMPS fan.
Hope this Helps.
May 07, 2011 | HP Media Center Photosmart PC (M7160N) PC...
I have a dell optiplex gx280 which seems to have a racing fan problem. sounds pretty loud, and varies. any ideas?
The fan bearings may be going bad. Variable speeds are normal as the fan adjusts to the cooling requirements.
Oct 24, 2009 | Dell Optiplex GX280 (99301) Motherboard
156 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
