Question about C3RS727LCD 4Channel Alarm with Remote Car Starter and Two Way AM
Remote start why wont my car start from far away?
Which fuse do I change my remote only works non inch away
Replace the battery in the remote control, clean the emitter lens on the remote control, and clean the face of your receiver. Should solve the problem.
Jul 31, 2014 | 2006 Mercedes-Benz CLK 500
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
My remote start on my 2005 Grand Prix will start the engine but shuts off right away.
is there any check engine light on??
well about GMC and chevrolet i can say that if there is any problem with the engine/the engine light is ON then the vehicle wont start, just an idea that may be there is the same reason with your car.
Dec 06, 2013 | 2005 Pontiac Grand Prix
Envirastation model dws 170
Usually it is due to bad batteries or remote is too far away from home unit. Put units next to each other and press the channel button on front of the home unit. It will start a search to find the remote. If it finds it with a temp reading press the channel button again and you should hear a beep. Channel is locked in. If you still do not get a temp reading try changing batteries in both units and try again. Another try is to unplug the home unit and wait several minutes with no batteries in either house unit or remote. Replace batteries in remote then in house unit and plug back into power. Set all settings and see if you get the reading. If not try step one again. Weak batteries will do the same thing as well as remote to far away from unit.
Oct 06, 2013 | Measuring Tools & Sensors
When i try to use my automatic start it just keeps beeping as it does when i am to far away. I cant unlock or lock my car or start it. The automatic start has been installed for 2 years. I have replaced...
Sounds like the unit itself may have blown a fuse and that's why it's not responding to the remote control. Have an alarm installer, or if you know how to, check the fuses on the unit to see if they're blown.
Jan 25, 2011 | Remote Start System
My remote start does not work in some parking lots even if i am right by the car. but other places works fine form far away
Make sure if you have a mercury switch not to park on the hill because the mercury inside the switch is going to make contact like the hood is open, if not put attention if this happen only when is windy, check the engine and trunk pin switch.
Dec 26, 2010 | 5303P LCD 2Way Security System with Remote...
Hi I have changed out my transmission in my 1996 voyager and now the engine wont start. The codes with the check engine light indicate 12 and 11. I have changed my crankshaft sensor and still nothing. Now...
The Caravan crank sensors are really touchy, if it is too close to the flywheel it wont start, and if its too far away it wont start, i would say you just out of range there, also make sure your shift selector harness is pluged in or it wont start. hope this helps
Dec 03, 2010 | 1996 Plymouth Grand Voyager
I bought a used dodge pickup equiped with a viper remote system,it worked fine until the last few days now Iam unable to start the vehicle with the key and keep it running.I took out the battery from...
On many of the Viper models, the symptom you are describing is because the remote battery is low. The remote can't be too far from the vehicle. If it is, the system see it as you forgot about the vehicle being remote started, and shuts it back down. A weak battery creates a weak signal and makes the unit 'think' you are far away. The Viper website has instructions on how to disable the whole system, there are many different versions, so find the box and get the model number from it, you will need that to get any further.
Jun 02, 2017 | Viper Televison & Video
I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
Jan 28, 2009 | 5900 SST 2-Way Security System / Remote...
C3RS727LCD 4Channel Alarm with Remote Car Starter and Two Way AM Logo
14 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
Charles Osborn
handt729
Level 1 Expert
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
