Question about Craftsman Garden
Trubleshootingcraftsmanlawnmower no fire to starter
  • Craftsman Master
  • 2,478 Answers
Check the start fuse between back of engine and dash
Posted on Jul 26, 2013
Why does it start, then starter disengages?
about the starter it sounds like the starter bendix is worn so I belive you should change the starter and it should work like it should, and since you changed the computer, you needs to do a relearn set-up
Jan 07, 2016 | 1998 Pontiac Grand Am
1998chevyvotex5.7 truck Firing Not
Is starter engaging? If starter is turning over but engine is not firing, check coil.
Apr 27, 2013 | Chevrolet Vehicle Parts & Accessories
1965 mustang starter fires but won't engage flywheel. it is a brand new starter
Doesn't matter. The forks inside the starter may be missing or broke off or bad spring in starter that pushes the gear out. Try new started. Starter may have to be shimmed to make contact with flywheel. Starter may be kicking out but not engaging flywheel.
Jan 17, 2013 | 1965 Ford Mustang
No fire to starter
Go to this link, may have something to do with your "no start" problem.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 20, 2012 | 1994 Buick Park Avenue
86 Chevy Suburban not starting.
Is the starter actually turning the engine over (engaging), or is it just whirring rapidly? If it is not engaging, then the vehicle certainly will not start. If it is not engaging, there is most likely a shimming issue to be addressed to get the starter to engage. If it is engaging, check carefully the large nut in the starter solenoid. There are usually more than one wire attached to this nut. Ensure that you have not missed replacing any of the wires that came off the starter studs. Some feed back to the fuse paqnel and can be critical for operation.
Dec 30, 2011 | Ford Ranger Cars & Trucks
Car won't jump start even with new battery
your starter could be bad, check it to see if it's drawing fire by turning your headlights on and have someone look to see if they go dim when you try to start it. if they go dim that means your starter is drawing fire, so starter most likely bad. or celinoid on starter is bad. either way you'll need to pull the starter. hope this helps you!
Aug 23, 2010 | 2006 Ford Taurus
I am out of fire starters, can I use paper, I cannot get my fire
That may be kind of difficult to do but it won't hurt the Egg. I would just put some unlit charcoal in the Egg then get some going in a chimney starter (also using newspaper by the way) and dump it on top of the unlit charcoal. You probably don't want to add lit charcoal directly onto the Egg's ceramic surface since it could crack. At least I wouldn't try it, my Egg cost too much :)
Apr 11, 2009 | Big Green Egg Large All-in-One Grill /...
Garden Logo
23 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
