Symbol DS6707 unable to program for qr code scanning
Can't seem to set this up for qr code scanning. Any one with experinece on this subject? Thanks, E
  • 74 Answers
SOURCE: I have symbol LS2208 handheld, Keyboard
If your barcode is $V scan the following barcodes from the LS2208 Product Reference Guide.
Begin New Rule
Specific String At Start
$ (from the Alpha-Numeric section of the guide)
S (from the Alpha-Numeric section of the guide)
End of Message (from the Alpha-Numeric section of the guide)
Send Control S
Save Rule
That should do it.
Posted on Jul 10, 2009
lserni
  • 466 Answers
SOURCE: Barcode line enter problem
This is a custom setting. You will find on the user manual (and also at the bottom of the Quick Start guide) a special barcode that, when scanned, toggles between "CR after barcode" and "No CR after barcode".
Posted on Mar 15, 2010
Yogger
  • 117 Answers
SOURCE: Can the Symbol LS4804-I400A scanner scan a QR code
No, this is a Laser Scanner. The laser beam can scan the barcode only in 1 direction (1D Barcodes). For QR Barcode (2D) you would need an Imager (Digital Scanner).
Posted on Nov 02, 2010
Yogger
  • 117 Answers
SOURCE: HI I HAVE ONE MOTOROLA SYMBOL
The EMEI Barcode and battery barcode are probably not the same length. When the scanner is set for specific length, he will accept only some barcodes.
Please check the length of the barcode. Set the scanner for two specific lengths or for any length of barcode. Try to scan again.
To set the scanner you would need programming barcodes. Those are listed in the DS6707 Reference Guide, provided at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf
Posted on Nov 18, 2010
Yogger
  • 117 Answers
SOURCE: When I scan with Symbol
There is probably an rule set on the scanner from the previous user. To be sure that you are not using any old settings. I would suggest to reset it to factory settings.
Connect the scanner to your Desktop PC. Download the Reference Guide for DS6707 at the page http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf Scan the Barcode Set All Defaults Scan the Barcode Erase All Rules
The scanner is now in factory settings and you can configure it as you need.
123scan - leanguage problem
http://www.motorola.com/web/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/General%20Purpose%20Scanners/DS9808/_Documents/_Static%20files/SYMBOL%20DS9808%20Quick%20Start%20Guide.pdf
there are bar codes for the country you are in underneth programing bar codes 3rd one down in the 3rd colom
if this helps you out pleazse take a moment to rate this. anything else i could assist you with?
Jan 14, 2013 | Symbol DS9808-SR00007NNWR - Motorola...
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
HI I HAVE ONE MOTOROLA SYMBOL DS6707 BARCODE READER TODAY ONE PROBLEM OCCUPIED. ANY MOBILE IMEI CODE SCAN BUT BATTERY NOT SCAN. SO PLEASE HELP ME
Nov 04, 2010 | Symbol DS6707 Wired Barcode Scanner
When I scan with Symbol DS6707 I normally get letter b showing up after the scanned numbers. Please help!
Oct 26, 2010 | Symbol DS6707 Barcode Scanner - P/N...
Is the ds6707 compatable with windows 7?
If connected with a CBA-U01-S07ZAR and programmed as the default HID keyboard USB host type, yes it should be compatible. The device uses the same drivers the host uses for a USB keyboard.
Jun 22, 2010 | Zebra DS6707 Bar Code Reader Barcode...
Mar 15, 2010 | Symbol DS6707 Wired Barcode Scanner
Can the Symbol LS4804-I400A scanner scan a QR code bar code?
Jul 14, 2009 | Symbol LS 4800 (LS4804-I400A)
I have a ls2208 symbol scanner that need to scan code 39.... The example below is return when I scan the following information. It seems to be do stange thing with the first 2 charecters. Can you help?...
Your scanner is set up for full Ascii mode.
$B = CTRL B
%I = >
Re-program to enable "Code 39" and disable "Code 39 Full Ascii"
In Code 39:
$B = Control key on
%I = Tab
Hope this helps.
Jan 10, 2009 | Symbol LS2208 Handheld
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
