Question about Lenovo ThinkPad R61 Notebook
Unlock password unlock supervisor password
How unlocked a supervisor password?
You can either type the password and remove it in the bios or clear the bios code.
Jan 30, 2014 | Toshiba Satellite Computers & Internet
Tip
Four Most Common Password Reset Solutions for Lenovo ThinkPad
<span> <p><img src="lenovo-thinkpad.jpg" />Lenovo ThinkPad Laptop password reset or recovery solution varies depending on which password you have forgotten. The hassle of<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-lenovo-thinkpad-password.html">Windows password reset</a><span> </span>process will range from simple inconvenience to total valuable data loss. For this, we have collected the most used Lenovo Computer password lost troubles and satisfactory solutions for you.<br /><b>Types of passwords for Lenovo ThinkPad Laptop</b><br />There are four kinds of passwords we will talk about Lenovo ThinkPad computer and the password reset solutions:<br /> <ul> <li>1&gt; Windows logon Password (Administrator, Domain and User account)</li> <li>2&gt; Supervisor Password</li> <li>3&gt; Hard Disk Password (Master and User)</li> <li>4&gt; Power-On Password</li></ul><br /> 1&gt;Windows logon Password for Lenovo ThinkPadWindows logon password for Lenovo ThinkPad is used to keep personal information private and we are always create some administrator or user accounts on Windows 7/Vista/XP PC and also domain admin or AD accounts on Windows Server 2000/2003(R2)/2008(R2). It will be a big besetment when you lost or misplaced the passwords of those accounts. However, with some easily password recovery ways, it is possible to re-access your Windows system with no damage of the data.<br /><b>Reset Lenovo ThinkPad Password with Password Reset Disk</b><br />If you are a cautious user, then you should have created a password reset disk for your Lenovo ThinkPad. So you just need to insert the password reset disk to<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html">reset Lenovo ThinkPad password</a><span> </span>directly.<br /><b>Reset Lenovo ThinkPad Password with Available Windows Administrator Account</b><br />If you can log on as an administrator for your Lenovo ThinkPad with a right password, then you can reset any other passwords of your lost or forgotten Windows logon accounts directly.<br /><b>Reset Lenovo ThinkPad Password with Windows Password Recovery Program</b><br />If you have not created a password reset disk previously, or cannot log on as an administrator with a right password, and for this situation, like me, you still have option to reset lost password for Lenovo ThinkPad PC with third-party software.<span> </span><b>Windows Password Unlocker</b><span> </span>is such a powerful Windows password recovery tool which enables resetting windows 7, Vista, XP, 2000, 2003 and 2008 password as blank with 4 easy steps:<br />1. Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker</a></b><span> </span>from its official site with an available PC<br />2. Burn a bootable CD/DV or USB flash drive<br />3. Reboot your locked Windows computer from CD/DV or USB flash drive<br />4. Reset lost or forgotten Windows password for Lenovo ThinkPad with easy<br /><b>Reinstall Windows OS</b><br />Reinstall Windows operating system for your Lenovo ThinkPad will be the last choose if you can reset Lenovo ThinkPad password successfully with those workable solutions that have mentioned above.<br /> 2&gt; Supervisor Password for Lenovo ThinkPadA Supervisor password protects the system infor stored in the BIOS. The user must input the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to alter the system configuration. If the Supervisor password is lost there is no way to recover it to enter the BIOS configuration.<br /><b>Reset Forgotten Supervisor Password</b><br />A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To get access, you need reset the BIOS password with some solutions like locate the jumpers or solder beads, or just contact the computer manufacturer or motherboard manufacturer for resetting forgotten Supervisor password.<br /> 3&gt; Hard Disk Password for ThinkPad ThinkPadThere are two Hard drive passwords: a user Hard drive password for the user and a master Hard drive password for the system administrator. The administrator can use the master password to get access to the hard drive even if a user has changed the user Hard drive password.<br /><b>Reset Forgotten Hard Drive Password</b><br />If the user's Hard drive password has been forgotten, check whether a master Hard drive password has been set. If it has, it can be used for access to the hard drive. If no master Hard drive password is available, or if the administrator forgets the master Hard drive password, then the hard drive must be replaced. For this instance you just need ask help from your computer manufacturer to reset forgotten HDD password.<br /> 4&gt; Power-On Password for Lenovo ThinkPadAn Lenovo ThinkPad Power-on password protects the system from being powered on by an unauthorized person. When it has been set, a prompt will appear during the system start up, and the Power-on password must be entered before an operating system can be booted.<br /><b>Reset Forgotten Power-on Password</b><br />If the Power-on password is forgotten and the Supervisor password is known, simply go into the ThinkPad BIOS setup utility and reset the Power-on password, otherwise try the following:<br />1.Power off the Lenovo ThinkPad computer<br />2.Remove the battery pack<br />3.Remove the backup battery<br />4. Please power on the computer and wait till the POST ends. If the password prompt does not appear then the Power-on password has been reset.<br />5.Reinstall the backup battery and the battery pack.<br /><b>Note:</b><span> </span>Some ThinkPad systems have the ability to reset the Power-on passwords in the ThinkPad BIOS setup utility if a Supervisor password has been set.<br /></span>
on Apr 19, 2011 | Computers & Internet
I forgot my supervisor password for my dell pc
Supervisor?
Which Password and which Operating System?
Bios Password? Hard Drive Password? Windows Welcome Screen Login Password?
Supervisor?
Apr 06, 2012 | Dell Computers & Internet
#5MFT3K1-595B. I FOROGOT THE PASSWORD AND CANT USE MY LAPTOP PLEAE HELP ME...
  • Hello cente_nkn, if by chance you didn't 'create a "Supervisor Password" to prevent anyone from changing the configurations in the BIOS / CMOS Setup? than we are 'OK!' Lets just say [No] for now.
  • Bootup / Start the computer, and follow these steps:
  • 1. When you hear the computer start-up, there will be a message that flashes very quickly at the bottom of the screen, it will read; Press F2 or F12 or on other "Computers, the 'Key Sequence may be [F11]..."
  • The area of your attention will be [F2] Key at the top of the keyboard. The F2 Key will open the CMOS / BIOS Setup. paul7of9_15.jpg
  • 2. Once this screen appear, you will see a 'Listing" of different set-ups. There will be instructions in the [right] Help ? area. You be using the "Arrow Keys" to (Select and Choose Items). In the first screen, there will be on the (right of the screen).
  • 3. Set Supervisor Password = This is the "Password Setting that will prevent anyone from getting into without authorization this area that you are in now, to "Change or Configure" CMOS or BIOS setting.
  • 4. Set User Password = This Password is use for "Logins / User Accounts...
  • You want to "Reset or Change the Supervisor Password.
  • Do so, and to finish; remember to use the [F10 Key] to 'Save the Changes.'
Thanks for using Fix' Ya, and I hope this fix it, paul7of9
Feb 10, 2011 | Dell Inspiron Notebook
Need to unlock ibm thinkpad 2374
I'm going to take my best shot at this....hope it works for you.
How to Reset an IBM ThinkPad Power On Password Using Hardware
If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
  1. Power off the computer
  2. Remove the DIMM cover on the bottom side of the computer.
  3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
  4. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed.
  5. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
  1. Power on the computer by pressing and holding F1.
  2. Enter the supervisor password. The Easy-Setup menu appears.
  3. Click on the Password icon.
  4. Click on the Power on icon.
  5. Enter the supervisor password and press the Space bar.
  6. Press Enter twice.
  7. Click on Exit; then click on Restart
Nov 07, 2009 | Computers & Internet
Ibm x31 password problem
Visit: http://www.ja.axxs.net/unlock/
  7. Click on Exit; then click on Restart.
Jun 19, 2009 | IBM ThinkPad X31 2672 Notebook
Supervisor password
A Supervisor password protects the system information stored in the BIOS. The user must enter the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to change the system configuration. If the Supervisor password is forgotten there is no way to reset it to enter the BIOS configuration. Setting a Supervisor password automatically sets the master Hard drive password. The following is the icon that comes up in the upper left corner if a Supervisor password is set:
A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To regain access, the system will need to be serviced to have the system board and hard drive replaced. Proof of purchase is required, and this repair is not covered under the warranty.
Document id: MIGR-59377 Last modified: 2005-06-17 Copyright © 2009 IBM Corporation Copyright © Lenovo 2009, all rights reserved
Mar 25, 2009 | Lenovo ThinkPad R51
Unlocked supervisor password
There are no backdoor passwords that you can use to get into your computer. The password is not stored on the BIOS and removing the BIOS battery will not help you. The password is stored on an EEPROM chip, you need a hacker who can solder a piece of hardware to this chip, run a program to read the contents of the chip to reveal the password.
IBM state that you need to buy a new motherboard to fix this problem.
Nov 30, 2008 | Computers & Internet
Supervisor Password Tosh 2410
If you don't know these passwords, then I don't think there is any way to unlock it. But reformatting your hard drive and reinstalling an operating system will fix this, and it will allow you to reset your own passwords. Hope this helps. If you don't wish to do it this way, then contact your computer's manufacturer and sk them for help; or you can also google the problem that you are having, and see if any solutions come up. Thanks
Sep 05, 2008 | Computers & Internet
Master hard disk bloked by passaword
can you pls described it to me, where the password pop-up when you use your pc?
Feb 15, 2008 | Televison & Video
Lenovo ThinkPad R61 Notebook Logo
63 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
