Question about Craftsman Garden
Starter will not engage no fire - Craftsman Garden
  • Craftsman Master
  • 2,478 Answers
Check your start fuse. Between back of engine and dash.
Posted on Jul 27, 2013
Everything works on the car but the starter wont engage and i just bought a new starter and battery
Take the starter back out but leave it connected. If it doesn't use a ground wire, make up a heavy wire and use that for ground.
When you hit the key, watch to see if the starter gear moves forward to engage an doesn't just spin. (it engages the flywheel when in place.) The engine isn't supposed to fire if it's not turning.
Aug 08, 2016 | 2001 Suzuki Grand Vitara
Starter just spins after ignition wire replaces - no fire
Sounds like you have the starter wires hooked up wrong and to continuous power. If starter shuts off with the key now, but wont engage the motor, you may need shims so that the starter drive lines up with the motors fly wheel
Apr 09, 2014 | 1995 Chrysler LHS
1998chevyvotex5.7 truck Firing Not
Is starter engaging? If starter is turning over but engine is not firing, check coil.
Apr 27, 2013 | Chevrolet Vehicle Parts & Accessories
1965 mustang starter fires but won't engage flywheel. it is a brand new starter
Doesn't matter. The forks inside the starter may be missing or broke off or bad spring in starter that pushes the gear out. Try new started. Starter may have to be shimmed to make contact with flywheel. Starter may be kicking out but not engaging flywheel.
Jan 17, 2013 | 1965 Ford Mustang
What can happen if the starter drive is not removed from the start?
If the starter drive is not removed from the start the engine will tent to drive the gear placing stress on the gear which will eventually wear off the gear.
Sep 10, 2012 | Champion Sport & Outdoor - Others
86 Chevy Suburban not starting.
Is the starter actually turning the engine over (engaging), or is it just whirring rapidly? If it is not engaging, then the vehicle certainly will not start. If it is not engaging, there is most likely a shimming issue to be addressed to get the starter to engage. If it is engaging, check carefully the large nut in the starter solenoid. There are usually more than one wire attached to this nut. Ensure that you have not missed replacing any of the wires that came off the starter studs. Some feed back to the fuse paqnel and can be critical for operation.
Dec 30, 2011 | Ford Ranger Cars & Trucks
The motor turns but will not start. It appears
. you lost me ! motor turns . that would make one think the starter is engaging. not firing might be ignition problem.
May 01, 2010 | Boating
Starter not engaging
it sounds as though the starter motor is on the way out. to confirm this, you need to have the started in a fail situation and place a test light on the signal wire of the starter. if it illuminates, your starter is bad.
Feb 24, 2010 | 1994 Dodge Dakota Club Cab
My honda accord 1996 lx won't start
Your starter bendix isnt engaging, if your replace your starter your problem should go away. The rappid ( firing ) you are hearing is the starter spinning but the bendix isnt moving out and engaging the flywheel.
Jan 07, 2009 | 1994 Honda Accord
Garden Logo
16 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
