Why won't my kenmore dryer/washer combo model 41797812702 go into rinse/spin cycle after the wash cycle that works fine
The washer fills up with water, goes to wash mode without problem, but won't go to it's next cycle which is the rinse/spin cycle
  • 185 Answers
SOURCE: Kenmore stacked washer/dryer - washer problem
check the timer
Posted on Mar 31, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
RescueTech
  • 145 Answers
SOURCE: Kenmore Washer 110.26912690 series 90
Hi Norm. Welcome to FixYa.
The first thing to check with the kind of symptoms your machine exhibits is the operation of the lid switch. Make sure that the pin/plunger on the lid itself has not broken off, and check the actuator lever on the switch itself. It is REALLY common on your model for the actuator arm to break off or crack, and this will cause no spin/no pump problems. Your machine is built by Whirlpool and the part number for the switch assembly is a 3849238. You can get it at any local whirlpool parts center in your area.
I hope you find this info helpful and thank you for allowing us to serve you.
Happy New Year from the FixYa crew!
Posted on Dec 27, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: Supra Wash/dryer combo Model SW5l30D
check the heating element for power.
Posted on May 03, 2009
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Mar 13, 2013 | Kenmore Washing Machines
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Jun 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
