How to fix ymgi indoor unit error code e6 - Heating & Cooling
5 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
hvac1960
  • 2133 Answers
SOURCE: hi there, we had blackout
E-6 Indoor/outdoor transmission error. error.
Posted on Jan 23, 2011
heinzhvac
  • 229 Answers
SOURCE: im getting an E6 error
Check your low voltage wires they are easily damaged. I have seen weed eaters cut the wires rodents you name it. check the wires closley also check the furnace circuit board check the 3 amp fuse it looks like a car fuse. if thew fuse is blown on circuit board your contactor at the A/C unit is probably bad. If this help please rate me and do a testimonial.
Posted on May 20, 2011
Voltas verticool showing e6 unit not working !! What happend?
From search I found that on a Mitsubishi it said e6 and e7 that is an indoor/outdoor communication error. I had that happen once when I installed one of these split units, got e6 and realized I forgot to connect the wire on the indoor part, that triggers the outside to go on when thermostat inside starts the cooling cycle. Maybe a wire pulled loose. There was terminal blocks on each unit on one I hooked up, check breakers too.
May 03, 2016 | Heating & Cooling
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Vertical AC error code E6?
E6 Indoor/Outdoor transmission error (signal receiving indoor)
Jul 24, 2015 | Heating & Cooling
Water leaking from unit
possible low pressure of refrigerant and freeze coil indoor unit, check filter maybe it's dirty
Jul 07, 2015 | YMGI R410A Ductless Mini Split 16 SEER DC...
Display error code E6
E6 is a comms error try turning the power off at the isolator and reset everything. if it comes back you might have a lose interconnecting wire between the indoor unit and outdoor unit
Apr 15, 2014 | Mitsubishi Heating & Cooling
What does e6 error code on aux unit
E6 usually means that there is a communication problem between the indoor unit and the outdoor unit. This could be due to a wiring problem or maybe you had a momentary drop in the voltage. Find the circuit breaker in the circuit breaker panel for your home/office that is connected to the A/C unit. Turn it off and back on and try using the A/C again. Sometimes the indoor unit is connected to one circuit breaker and the outdoor unit is connected to another one. Make sure you have disconnected and reconnected both before running your unit. If that does not solve the problem you may need to have some cable replaced between both units.
Mar 19, 2014 | Heating & Cooling
What does error code E6 mean? On a Mitsubishi Mr. Slim A/C
Code E6
Error detail Indoor/outdoor unit transmission error (signal receiving error).
Inspected unit Indoor.
Air Conditioning Fault Codes
Aug 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi there, we had blackout last night and our ac unit mitsubishi electric has an error code E6 is coming up! how can i fix this problem?Thanks
Jan 23, 2011 | Heating & Cooling
Mitsubishi electric, AIR CONDITIONER model peh-8,10, 12myc ERROR CODE E6 ,
E-6-Indoor unit heat exchanger sensor [ThIR] defective (resistance is open circuit or closed circuit).
• Poor connection of sensor connector on the indoor PCB.Rectify or replace sensor.
Jan 04, 2011 | Mitsubishi Heating & Cooling
Hi I have mitsubishi aircon with an E6 error code. How do I fix it?
E-6 Indoor unit heat exchanger sensor [ThIR] defective (resistance is open circuit or closed circuit).
• Poor connection of sensor connector on the indoor PCB.Rectify.
Dec 05, 2010 | Mitsubishi MS12TN Air Conditioner
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
