Question about LG LUV400T Bagless Upright Vacuum
Brush won't turn on lg luv400t bagless upright vacuum
Belt is not broken and is connected to the motor. The reset button is engaged
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Beater brush will not turn the belt is not broken
make sure the round switch on the bottom front is in the right possition.The brush want turn if the beater is in the upright position.It has to be in push position for it to engage the brush motor
Nov 17, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I cant get the power brush to work is there a reset button? the vacuum is only 2 months old dirt devil 12amp bagless featherlite
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Apr 06, 2009 | Dirt Devil M085850 Featherlite Bagless...
Dyson DC14 animal bagless upright
Make sure unit is on carpet setting. If is is chances are the belt connecting the clutch to the motor is broken.
Aug 03, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Were is brush reset button please
I don't believe the Dyson has a reset button. if the brush doesn't turn when the handle is down then you may have a broken belt. there are 2 belts on the vacuum, the one from motor to clutch can be replaced from under the vac. the belt from brush roll to clutch is not available and must be replaced as a clutch ***'y.
J
Jun 13, 2008 | Dyson DC18 all floors Bagless Upright...
Premalite vac brush stopped turning
Not familiar with thi sbrand, but a reset is for when the brushes get jammed pr stalled, it will trip the reset. Make sure that the brsuh roll turns easily, also for a broken belt and/or bad brush roll. Some resets are for when the vac motor over heats, it will trip saving the motor. Usually this is for a jammed brush roll or a clog.
Apr 23, 2008 | LG Electronics Premalite Vacuum Bagless...
LG LUV400T Bagless Upright Vacuum Logo
Top LG Vacuums Experts
Think Crucial
Think Crucial
Ed Mac
Are you a LG Vacuum Expert? Answer questions, earn points and help others
