Question about Lands Phones
At&t manual model E2811
Need to set code to listen to voice mail while away from home???
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lands Phones Master
  • 102,366 Answers
One Wire
  • 126 Answers
SOURCE: checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any
touch-tone telephone.
1) Call your telephone number and wait for the system to answer. If the answering system is
off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered within 2
seconds. You may select a command from the following chart:
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
corresponding command, it starts the Recording function. If you want to stop the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
is in the command waiting mode. You may enter another command at this time from the
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Posted on Jan 26, 2008
mohammed387
  • 1952 Answers
SOURCE: need manual for uniden exa18580 cordless phone
phone.manualsonline.com/manuals/mfg/uniden/exa18580.html - 43k
Posted on Jan 03, 2009
SOURCE: access voicemail from another line while away from home
The previous solution only works for older machines. I have the same Panasonic model and this works every time.
On your handset, hit the top center button(menu). Touch the arrow down button 7 times. Should say "Initial settings". Hit top right button on handset (display shows this is now the "select" key). Display now shows "Set Answering". Hit top right button again ( select key). Display now reads "Ring Count". Hit arrow down button 2 times. Display now reads "Remote Code". Hit select key again and enter your desired 2 digit remote code. Hit "Off" key. When you call the answering machine from the road, simply enter those same digits. Piece of cake. Enjoy.
Posted on Jan 10, 2009
SOURCE: how do I retrieve my voice mail when I'm away from home?
Go to the base unit.
scroll to the answering machine option.
Under there is a setting for your security key.
you can read what's there, or change it to your own two digit code.
when you call in, during the message, enter that two digit code and it'll go into messages. There's a "toll saver" mode so that the machine answers after two rings instead of 4, so that if you call and it rings 3 times, you know there's no new messages.
Manual:
http://www.uniden.com/pdf/DCT648-2om.pdf
Posted on Feb 21, 2009
dirinda89
  • 214 Answers
SOURCE: Lost operators manual; need to know how to set up
Here's a link to download your manual. Just scroll down & click on 'download now'. If this helps plz rate this as 'fixa'. If you need more help leave a comment & I'll be happy to help you. Thank you kindly.
http://www.generalmanual.com/Telephones/Panasonic-KX-TG6051M-Expandable-System.htm
Posted on Mar 04, 2009
How to change voice mail
Depends on if it is from a base unit or if it is a telephone carrier voice mail?
Base Unit. Google
make model manual
Telco, phone them and ask if it is including in your plan, how to set up and how to dial in and listen to messages.
Feb 14, 2018 | Lands Phones
How do i retreive my voice mail messages
hold the #1 down until it dials your voice mail for you, then listen to messages. push 7 to erase one & push 9 to save one after you listen to them. Phone does not come with voice mail set up already, so if this is a new phone for you, you will have to dial 1 & hold button down until it rings & it will walk you through setting it up
Feb 23, 2015 | Tracfone Wireless LG 440G
How to empty my mail box
Here's a possible solution I found with a search engine:
I believe your callers MAY be reaching a "Voice Mail" system that is part of your phone service - from whatever service provider you have.
To confirm that this is true, simply disconnect the main base unit from the phone cord and then call your home number from another phone (such as a cell phone). If you still hear that "mailbox full" announcement, then you have confirmed that there is some kind of voice mail system active - and full - on your home phone number.
So what that means is that you will need to contact your service provider and get the official instructions on how to access that system - to listen to and delete any messages that are there. Each service provider has different procedures, but you can often call your own number - from your home phone - and get straight into the system. Once connected, there should be "speech menu" that will guide you through the messages and how to delete them.
Also, you may want to configure or disable this voice mail system so that the Uniden has a chance to answer calls while you are away. This usually involves either setting the number of rings on each system so that your Uniden can answer first, by having a lower number of rings than the voice mail system.
There may be other steps needed IF this voice mail issue is not the problem.
Aug 25, 2014 | Uniden Lands Phones
How do I listen to the voice mail on vtech 6.0
Since you declined to specify the model of your VTech phone, please enter it into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Apr 19, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How to i listen to my voicemail away from home
All you need is to log on to your mail box and click for the voice mails that are received on to the box. You need to dial the country code to get to your service provider in case you are roaming and could be obtained by calling the toll- free of your service provider.
Jun 27, 2012 | Cell Phones
The voice mail icon won't go away, even though I
full factory using jaf or ufs gadget will solved your problem.go to the nearest cellshop sir.
Jun 16, 2010 | Nokia 6101 Cellular Phone
The voice mail icon won't go away, even though I have listened to and deleted the voice message I had on the phone. I've tried turning the phone off and on and that doesn't work.
Hello Bro,
Try this select Menu >Settings > Restore factory sett.. Enter the security code.
hope this Helped you....Thanks for Contacting FixYa..
Apr 23, 2010 | Nokia 6101 Cellular Phone
How do access my panasonic kx-tga101s voicmail ?
First of all; Do you have the user guide manual? If not you can download it for free at...www.static.tigerdirect.com/pdf/panasonic_kxtg10325_manual.pdf
This manual addresses handset kx-tga 101s.
The unit lets you know when you have new voice mail, in the following ways; "new voice mail" is displayed on the handset; The message indicator, on the handset, flashes slowly if message alert is on. In order to listen to your voice mail messages, you must dial the telephone service providers voice mail access number. If the handset still indicates messages that have been listened to turn it off by pressing and holding "CLEAR" until handset beeps.
Do you subscribe to a service package that includes voice mail? If so, to use that service turn off the answering machine; And use the instructions provided by your service provider. If you want to use the answering system, call your service provider to deactivate your voice mail service. If service provider cannot do this then set the answering system "RING COUNT" so the system answers calls before voice mail. Check with your service provider to find out what the ring count of the voice mail service is , then make the answering system ring count so it answers first.
Let me know if this answered your question.
FixYa WIZ....saailer@att.net
Dec 05, 2009 | Panasonic KX-TGA101S Cordless Handset
Lands Phones Logo
29 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
