Question about Craftsman 10" Table Saw
Craftsman table saw problem...shuts off
My craftsman table saw starts up and then makes a binding sound and trips out with no cutting involved...the blade moves freely with the poer off
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 360 Answers
SOURCE: no book.how to square craftsman table saw mod 137 blade to table
Thanks for using Fix Ya
To download the owners manual for your saw, click --->here<---
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 15, 2009
efs_perpends
  • 1996 Answers
SOURCE: Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
bozcro
  • 867 Answers
SOURCE: my craftsman 10 inch table saw vintage late 70's
electric motor needs a rebuild, bearings and brushes worn
Posted on Jul 25, 2009
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
My craftsman 10 " table saw will run for about a second and then it shuts due to the breaker tripping or the GFCi outlet tripping.
That's saw draws around 15 A while running. Make sure that you have that much to spare on the circuit
May 21, 2017 | Craftsman Saws
New to table saw use, have my husbands old 10 craftsman, was learning to rip with it doing fine, then it started to bog down during cut until the blades stops, moving. put on a new blade and noticed...
If I understood correctly, you started using your husband's table saw and while ripping boards, you managed to stall out the blade AND motor?! If that's the case, you probably have a very dull blade and are binding your board on the blade. Neither is safe and it sounds like trouble is brewing.
First and foremost, get someone to show you how to safely and properly use and adjust the saw if you are new to wood working and power tools. That saw is capable of turning your lumber into a high speed missal if you do things improperly.
It also sounds like you tried installing a new 10" saw blade. Changing the blade requires 2 wrenches. One to hold the arbor and one to tighten the nut. The blade itself should rest on the arbor between two large washers. Also make sure you install the blade so the front face of the cutter teeth face you and rotate toward you. Make sure the saw is unplugged when changing the blade and never turn on your saw with a loose blade.
Oct 20, 2013 | Craftsman 10" Table Saw
Motor makes loud binding sound then trips. shaft turns slowly like in a bind as well.
sounds like a bearing in the motor, possibly brushes need replacing also. But most definitely a bearing.
Sep 14, 2011 | Craftsman Saws
I have been using my Craftsman 10" Table Saw to
First things first, check the outlet that the saw is plugged into. Does it have power? If so then progress to the saw itself and check the reset button which is usually located on the front panel but sometimes on the back or sides. Press the button firmly to make sure it is not tripped and if it is this will reset it. Make sure the power is turned off and attempt to turn the blade manually ( caution,
the blade is sharp so a pair of gloves is recommended ). If the blade turns with very little resistance then turn the power back on and try the on/off switch. If the saw starts it may very well have been the circuit breaker that had tripped.
Mar 02, 2011 | Craftsman 10" Table Saw
While cutting a piece of scrap plywood on my Craftsman 10" table saw, I accidentally cut through a bolt and it caused my saw to shut off. I pushed the reset button several times, but it doesn't feel as...
First off the saw will have to cool down and then the reset button will take some major force to reset. You should hear a distinct click when it does...
heatman101
Sep 20, 2010 | Craftsman 10" Table Saw
I have a Contractor's Craftsman 10 " table saw, #113.29884, that will not tilt to a true 45.degrees. It starts to bind up at about 43 degrees and refuses further tilt just shy of true 45 degrees. Thus four...
yes there is, first I would unplug the tool and tilt on its back and thoroughly try and clean the debris from the undercarriage. Then go to managemyhome.com and download a manual for this, I was looking at page 55 and it talks about how to reset the saw to make square cuts. Let me know if you need more assistance
Aug 25, 2010 | Craftsman 10" Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
May 11, 2010 | Craftsman 10" Table Saw
Half way through cuttig a 2*4 my crAFTSMAN table saw cut out. Hitting the trip switch had no effect. Power source is good. Is there something I'm missing
The trip circuit has a time delay for resetting. Wait about 30 to 60 seconds and it should work when resetting.
Oct 06, 2009 | Craftsman 10" Table Saw
Craftsman 10" Table Saw Logo
63 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
