Question about Saws
Delta 14" band saw motor
Motor will not turn over. Is it possible to replace the brushes on this motor or is the motor shot?
    Sergeant:
  • 468 Answers
What kind of motor is it? I would suggest to look for local electric motor shop. You can also call Delta.
Posted on Jul 25, 2013
efs_perpends
  • 1996 Answers
SOURCE: I need a manual for the Delta band saw model number 28-207
Go to this link, Right click on the underlined PDF below the Publication Preview, and you'll be able to save target as a pdf file onto your system.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 05, 2009
efs_perpends
  • 1996 Answers
SOURCE: Have a Delta band saw 28-245 and looking for an
Here's a link to a parts diagram and list at Delta. Unfortunately, no manual online there.
Look through the list here and maybe there's something you can use instead.
SOURCE: i have a jet band saw- 14 mw-- and the adjusting plate has failed
I have the same problem and am having no luck in finding replacement parts. Did you have any luck find the part?
Posted on Oct 02, 2009
heatman101
  • 43501 Answers
SOURCE: 14" Delta Bandsaw keeps tripping the internal motor breaker.
The first thing that I would check is the wiring to the saw. My guess is that the wire to the saw or the cord is not heavy enough.
As saw like that can pull a lot of amps. Probably 15 or more when working hard. What happens is that when the amp draw goes up and the cord is too light, the voltage drops which increases the amps. and starts a vicious cycle...
The one thing that finally gives is the internal overload in your motor.
Try running heavier wire or a heavier extension cord if you are using one.
#12 wire or a 12 wire cord would be minimum, if running over say 50 feet then you should be looking at #10 wire.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 29, 2009
Testimonial: "Thanks. I will replace the power cord. I do not use an extension cord."
rowdy45176
  • 2176 Answers
SOURCE: delta band saw 14inch cat28-243 manual
go to Dewaltservicenet.com and type in your model number in the middle of the page towards the bottom and you should be able to download an owners manual for this tool, if you have a problem let me know and I will try another site for you.
Posted on Dec 23, 2009
What are all yours phone number
I ordered my band saw blades on sawblade.com . I mostly cut metal tubes and some pipe work. I used bi metal band saw blade.
May 21, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
What makes a delta 28-243F 14" band saw blade keep coming off?
The most common is wheel misaligment. The top wheel has an adjusting screw or the equivalent somewhere, and you can turn that to align the blade to the center of the wheels.
Second most common is guide problems. There are some guides that are supposed to hold the blade "just right" above and maybe below the table where you are cutting These must be set to support the blade in it's correct position as you are cutting through the material you are cutting.
3rd problem is a saw blade that has lost it's tension from being
" worn out ".
Be blessed.
May 20, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
Motor replacment
Try to contact ereplacement . Or check out the motor from Baldor electric company. They have available motors. If you need band saw blade, my supplier is sawblade.com . Check them out.
Nov 11, 2013 | Delta Machinery 14" Band Saw with 1HP...
Riser block
6in riser block for Delta 28-276 14in bandsaw ..
www.bandsawblog.com
Nov 29, 2012 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
Delta 28-160 band saw 3 wheel, blade keeps coming off
Sounds like your tracking screw needs adjustment, located right beside the knob used for tightening after adjusting the tension on the blade. Allen wrench required. Turning right pushes out and turning left pulls it in. A little is a lot when adjusting this screw. Always turn the blade in the same direction as the cut while adjusting.
Nov 27, 2012 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
My Delta band saw motor is having issues. I was
I would bet it's the Motor Brushes.They are locaded on the housing of the saw, accesed by unscrewing the plug.The brushes are replaceable and your saw will be fixed.Where to buy replacents could be an issue,Check manufacturer or search power tool replacement motor brushes.If stuck you can try to unscrew the plug the brush is at the bottom engaging the motor armerure,there shoud be a spring keeping contact.Inspect brush condition it looks like a carbon block worn to the curve of the motor.Go online do a search on how electric motors work you'll see exactly what I'm explaining.Cheap part easy fix.Good Luck.
Sep 05, 2009 | Saws
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
