Question about Kenmore ICP Comfortmaker C4A624GKD 2 Ton 16 Seer AC w/ Coil Lineset & Accessories
Comfortmaker rpj2 I am looking to replace furnace unit Model GNJ100N16A1. Looking for a new unit similiar size Natural Gas.
Can I convert from natural gas to propane
Yes... you just need a retrofit kit.
Jan 26, 2016 | Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
Comfortmaker PAT 336K00A1
Cliff, this is Teng. Look inside your furnace if there is any flashing code. If your furnace is recently installed it should have electronic control board.
Nov 10, 2013 | Comfortmaker 7.5 Ton Heat Pump W...
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Where can i find a manual for an old comfortmaker gas furnace that's about 50 years old. The model #GC400050-08M. The blower works and the pilot light is on, but no heat is coming out of vent. The flames...
Tie red and white wires together after removing thermostat from wall, if unit comes on replace thermostat, if not check limit controls for continuity, Good luck.
Mar 02, 2010 | Heating & Cooling
Looking to change heater3e239 to gas from lp what parts do i need
Contact graingers at grainger.com. Give them the model number and tell them you need a conversion kit from LP to Natural Gas.
Jan 19, 2010 | Dayton Gas Furnace Heater
Comfortmaker furnace will not light!!
Make sure you have gas to the unit and the switch on top of valve is turn to on. Can you here the gas valve click? It igniter comes on and a delay and the gas valve should come on. Kill power to furnace to reset control board. Rus Let me know how it goes.
Nov 17, 2009 | Heating & Cooling
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
How do you change oil gun in furnace to natural gaswe want to go to natual gas and don't know how to change the gun over
You will need to call a professional to size the right orifice, inducer, and primary air intake for your application. If it is a residential unit you probably won't have much luck finding a conversion. Your best solution is replacing it with a gas furnace.
Oct 04, 2009 | Heating & Cooling
Kenmore ICP Comfortmaker C4A624GKD 2 Ton 16 Seer AC w/ Coil Lineset & Accessories Logo
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
