A
Anonymous Posted on Jul 25, 2013
Is there a linux ubuntu driver for kyocera mitra printer km-2820
5 Related Answers
Anonymous
  • 43 Answers
  • Posted on Mar 02, 2008
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Anonymous
  • 2120 Answers
  • Posted on Jan 15, 2009
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Anonymous
  • Posted on Mar 12, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Anonymous
  • Posted on Feb 22, 2010
SOURCE: I am new to Linux. How do I instal an Epson SX210
Try this:
http://blog.sadhill.net/impresora-epson-stylus-sx210-en-ubuntu
Anonymous
  • Posted on Jul 20, 2010
SOURCE: looking for linux drivers for Epson SX215 printer
get the Epson Linux drivers from the Avasys site and install them
http://www.avasys.jp/lx-bin2/linux_e/spc/DL1.do
2answers
When i connect my kyocera km c2525e to the computer its picked as OEM 2JL-25C
Hello, connect your copier in a network and you can use the drivers from this page https://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.KMC2525E._.EN.html
Km 2820
What error code are you getting? It could be a lot of reason for paper to get stuck, there is always a error code associated with each jam
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
5helpful
2answers
Try this:
Kyocera cs-c4035e driver for mac 10.5.8 platform have older driver which works but won't give me color
You can copy and paste any of these links into your address bar to bring you to the driver download site:
www.nodevice.com/driver/KM-4035/get35425.html
driverscollection.com/?H=KM-4035&By=Kyocera...5
www.opendrivers.com/driver/.../kyocera-km-4035-twain-source-driver-v1.10.1-windows-os-free-download.html
2helpful
Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
k24674
ADMIN Andrew
ADMIN Andrew
