Question about Vacuums
Eureka power plus
HOW DO I REEMOVE ROLLER BRUSH ON MY EUREKA BOSS SUPERLITE MODEL 402A.IT DOESN'T TELL YOU IN MANUAL AND THERE ISN'T ANY SCREWS ON TOP OF HOOD COVER.
  • Vacuums Master
  • 18,408 Answers
Go to page 8 and it tels you to lift access door latch
http://www.eureka.com/FileLibrary/f3193922a9de44d6b4ee8db926c621d3/70878B.pdf
Posted on Jul 26, 2013
SOURCE: Eureka model 4335 - belt removal (top cover)
loosen two screws on either side on top of the housing lifts off the top. exposing the roller and the broken belt.
Posted on Mar 25, 2009
galati2k
  • 281 Answers
SOURCE: Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Posted on Apr 23, 2009
susho
  • 18 Answers
SOURCE: Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Posted on Jul 31, 2009
Vac Belts
  • 701 Answers
SOURCE: My Eureka The boss Smartvac Model #4870 roller
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Posted on Dec 11, 2009
  • 1206 Answers
SOURCE: Eureka the Boss Power Plus belt problem
it could be the beater bar (brush) has bad bearings at the ends or burs on the beater bar section the belt rides on,my money is on the bearings.
Posted on Jan 24, 2010
Jan 24, 2010 | Vacuums
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Bissell 4870 Belts
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
Belt seems to have broken where do I get new belt for my eureka
If this is the same model as the one you have dont forget the 402A has a brush roll on/off function located on the main power switch so that it can be used with the beater bar on or off. If you remove the sole plate you'll find a toothed drive belt. These don't normally break and can be difficult to find a replacement. Check EBAY or Electrolux/Boss for replacements. It may just have slipped off its mechanism.
Jun 16, 2009 | Eureka 402A Bagless Upright Vacuum
Change vacuum belt
This unit is not designed for the consumer to change the belt. Eureka recommends you to take it to a service station to have this done
Dec 19, 2008 | Eureka 402A Bagless Upright Vacuum
Download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Sep 15, 2008 | Eureka Boss Superbroom Bagless VacuumStick...
Eureka Wide Track Superlite vacuum roller brush motor
Don't know if you can find something that will work, Eureka doesn't make these motors available thru them. Try some local shops or a place that sells small motors.
Jun 14, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Vacuums Logo
73 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
