Question about Ricoh Office Equipment & Supplies
Abnormal termination I have a scanner which will usually scan to a folder successfully. Every once in a while, it fails and logs it as "Abnormal termination under output"
  • 82 Answers
SOURCE: hp photosmart c3180
Try this
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=23227&lc=en&cc=us&dlc=en&product=1146331&lang=en
Posted on Jan 05, 2008
Basti
  • 1447 Answers
SOURCE: Runtime Error
Try this link:
http://support.microsoft.com/kb/178385/en-us
and install the executable file that you can find in this link
http://download.microsoft.com/download/streetstrips2000/utility/1.0/win98/en-us/runtifix.exe
When you get the error and click on details, what is the exact error that you see?
Posted on Apr 17, 2008
SOURCE: HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Posted on Jan 22, 2009
SOURCE: All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Posted on Jan 23, 2009
GuruFixya
  • 34 Answers
SOURCE: Program crashes as soon as it launches
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Posted on Apr 27, 2009
Runtime error abnormal program termination
Sounds like you have ran a scan on your drive and the software has become corrupt.
Download the utility from Seagate and try again
Feb 08, 2014 | Seagate Back Up Plus Desktop Drive...
To do with Lock on.Air combat Simulation. whilst trying to install same, I keep on getting a message, saying.Abnormal Program Termination. no idea how to get to grips with this, has there is no other...
A method for warning abnormal connection between two bluetooth devices allows a user to adjust a distance between two connected bluetooth devices and to take an average obtained from several quality values read at that distance as a comparison value. Thereafter, a CPU of any one of the devices gets link quality value periodically by a host controller interface (HCI) command. The CPU will send out a warning message to mention the user of the bluetooth device when the quality value is lower than the comparison value, i.e. the connection is abnormal. And then, the user can handle it immediately, for example, pulls the two devices closer to lower the probability of the connection termination. The invention can reach the abnormal connection warning requirements for different users, and allows different users to have abnormal connection warning establishment for different distances.
An onboard device abnormal connection notification system is provided with: onboard devices (3a, 3b) which is connected to an in-vehicle network (5); a monitor means (1) which is connected to the in-vehicle network (5) for monitoring an abnormality in the state of connection between the onboard devices (3a, 3b) and the in-vehicle network (5); and a notification means (2) which is connected to the in-vehicle network (5) to notify an abnormality in connection of the onboard device (3a, 3b) based on a demand from the monitor means (1).
Jul 03, 2008 | Computers & Internet
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
A9 ERROR CODE CAN NOT FAX
A9 is Brother's code "Abnormal scanning reference voltage"; try restarting the fax machine and trying again, or replace the scanner unit. (per Brother's website)
Jun 24, 2009 | Brother MFC 7420 All-In-One Laser Printer
Runtime error that says abnormal program termination
i tried and it worked like this
deinstall windows sp 3
download microsoft 2008 c++ library
install vcs 1.0
install update vcs 1.0 may 2008 from panasonic support
May 06, 2009 | Panasonic SDR-H60 HDD Camcorder
Microsoft Visual C++ Runtime error: abnormal termination
Download and install visual C++ here: Click Here
Then restart the computer
May 02, 2009 | Sierra Online, Inc. Half-Life:...
Picture it 2002 terminates when trying to open a project
Hi all!!! I am soooo excited!! I found a solution to fix the abnormal program termination with my picture it 2002!!!! Many, many thanks to John Inzer who made this info available!! I am no computer expert, but persistence and research paid off! My software is now up and running!!!! Click on the link below: microsoft.com/downloads....etc.
The best part is that it doesn't cost anything!!
Eve
Albirt wrote:
> Hi. I am having same problems with picture it.
> "Runtime error / abnormal program termination" message when I try to
> open picture.
> Windows XP and Picture It 2002 Photo.
> Could you reload file to yousendit ?
> Thanks
No problem....try the following link:
http://www.yousendit.com/download/UmNLcmxTSWVrWS92Wmc9PQ
The patch is also available from
Microsoft Download Center:
Picture It! Publishing 2002:
Patch for 19299 (PI19299.exe)
http://tinyurl.com/dfeq28
or...
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=0fb68178-d6bd-41bd-9f00-f44ac7ca9e28
Mar 08, 2009 | Microsoft Picture It! 2002 for PC
E07-11 check scanner unit
you may check the sensors(home position sensors) of the scanner unit because e711 means abnormal platen scanning
Aug 13, 2008 | Panasonic Workio DP-2500E Copier
Keep saying check printer
5.5.3.3 ##324 [Rx] Printer section scanner motor rotation rate abnormal 0003-5251
Cause
An internal mechanism is faulty.
Remedy
1) Check the connection between the laser scanner unit (J802) and SCNT board (J6).
2) Replace the laser scanner unit.
3) Replace the SCNT board.
Jun 05, 2008 | Canon L220 Plain Paper Laser Fax
Black output
This type of issue could be related to different sources. First step I would do is check to see if the lamp is coming on within the scanner, possible bad lamp. One other possibility would be the CCD failure, it may not be moving across to capature your film. Also, when attempting to scan does the scanner sound normal or abnormal. If abnornal sound is occurring then CCD could jammed/stuck hardware failure. Last step would be uninstalling/reinstalling your scanner software, check for updated drivers from the manufacture of your scanner. At this point if none of these suggestions helped then test scanner on a different computer system.
Sep 02, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
860 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
