Question about RTO Letro Jet Vac Automatic Pool Cleaner without Booster Pump
Replacement Part Emerson 1081 Pool Motor, Model K63 CXERE 4772, HP 3/4. Missing drain plug (o-ring also if it has one). Do you carry this part?
I need a manual
For what?
its just a motor.
do you need wiring assistance?
what is the model, code or serial number of the Emerson motor?
and... 1081 does not help!
That just means it's a 'Pool' motor casing.
Feb 16, 2014 | Emerson Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
Emerson 1081 manual
What Emerson model, serial and or catalogue number do you have? 1081 is the basic and generic code indicating that it meets the standards for a pool motor, that's all.
Oct 16, 2013 | Emerson Pool & Spa
How to replace the capacitor on emerson 1081 pool pump motor
remove the bump on the motor make sure power is off then discharge by shorting a screwdriver from the leads to the case then take a picture of wiring or make a note then match it up at a electrical supply store then replace
Jul 07, 2012 | Emerson Pool & Spa
I need to replace the bearings on a 1.5 HP Emerson 1081 Pool ump, Model number K62CXESE4792. Can I get the bearings from you?
YOU WILL NEED 1 OR TWO 6203 2RS AND MAYBE A 6204 2RS, THIS MOTOR CAN USE 2 SIZES OF BEARINGS. YOU CAN GET THEM FROM YOUR LOCAL AUTO PARTS STORE $$ .. OR SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY, IF YOU ARE LOCAL ? LONGWOOD FLORIDA. I'D GIVE THEM TO YA FOR FREE , NO CHARGE !
Jun 06, 2011 | Emerson Pool & Spa
I have emerson 1081 (model # K63CXETN-4820) pool motor. I am looking for impeller for this motor. Can you plz point me to where can I get the impeller?
that motor will fit all sorts of pumps, YOU NEED TO KNOW WHAT KIND OF PUMP you have,, hayward,jacuzzi.. the motor pictured is a round flange.. look on ebay to see if you can find that looks just like yours ! than ask the question..
May 12, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Where can i order the impeller (center dish cover) for a emerson 1081 3/4 hp pump
The impellers for the motor depends on the actual brand of pump that the motor is actually bolted up to. Impellers are available anywhere and once you can let us know what the actual model of the pump (should be a Hayward, Jandy, or it may be an off brand) we can not only provide you with the part number, but also a location where to purchase. What is probably happening is that you are searching for the impeller for an emerson, instead of looking for the imepller for the appropriate pump.
Feb 07, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
I have an Emerson 1081 Pool Pump Motor , every time I turn it on it trips the circuit breaker , is the motor bad ?
Well, something is wrong. Either the pump or the wiring from the switch to the pump. Pull the pump and take it to a motor shop and have them check it out.
Oct 19, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
When I turn it on it blows the circuit
First you need to remove the wires from the back of your motor and wire nut them off. If the breaker still blows it is probably in the circuit to the motor if not it is probably in the motor and will need a new one unless it is bigger than 2.5HP then it may be worth rewiring. If it is blowing the breaker and is in the motor it is time for a new one.
Oct 03, 2009 | Emerson Pool & Spa
RTO Letro Jet Vac Automatic Pool Cleaner without Booster Pump Logo
43 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
