Question about Toshiba T-6000 Toner Cartridge for Use in Estudio 520 600 620 720 850 - 6,
Toshiba estudio 600 showing message service recommended IQC
Service recommende SPC
2 Suggested Answers
  • 628 Answers
SOURCE: my toshiba e-studio 550: service recommended for SPC appeared
Check the control status of the surface potential sensor (05-242).
<When “4” is displayed: sensor error>
The sensor detection value is abnormal or the sensor output value is not changed even though
the main charger bias value is changed.
Is the connector of the surface potential sensor connected properly?
Is the main charger grid/wire attached poorly?
Is the main charger attached poorly?
Are leaks and such occurring?
Posted on Mar 06, 2009
Toshiba estudio 600 when i make 20 copies it makes only 6 copies then it stop and message on display wait after 2 to 5 minutes after it makes 5 copies sir can u give me exact problem thanks
This seems like fusing problem, whether heat is not enough...
U need to check your fuser unit thoroughly, such as heater roller, IH coil, and board.
Sep 18, 2013 | Toshiba e-Studio 350 Copier
SERVICE RECOMMENDED FOR IQC
If just to clear the message:
Enter 08 mode by pressing 0+8 keys and ON the MFP
Enter "000" and press START.
Reset the value shown to "0". Reboot machine.
Mar 08, 2011 | Toshiba COPIERS E-STUDIO 520 Copier
Toshiba DP 8070 has Service recommended for IQC
there is a rubber blade similar to the wipers on your car, that clean the drum. when there is an obstruction under the blade it does not clean that area around the drum leaving that line. i would say a technician needs to be contacted.
Mar 09, 2010 | Panasonic DP-8020E Black and White Copier
Refill toner cartridge
The toner cartridge is designed to dispose once finish... Not recommended to modified and refill...
Feb 17, 2010 | Toshiba E-Studio167 Copier
Have a Toshiba E-Studio 350 in the field, and just lost our Toshiba tech. Copier is showing a wrench. Any recommendations?
Wrench appear in the LCD touch screens mean "call for service". It will freeze the copier from operating until the problem is fixed.
There will be an error code appear when you press "CLEAR" and "3" button at the same time. The error code should appear next to the wrench icon you mentioned.
It is recommendable to get an experience tech to solve the problem for you.
Jan 19, 2010 | Toshiba Estudio 200L Copier
I have a problem with my TOSHIBA DP8070 coper. i get error message: IQC service call recommended " the print quality is very poor
this happens during automatic color calibration, more than likely you need new color developer installed by a technician. turn machine on holding the 0&8 buttons to enter service mode type 4546 and 0 then start and 556 and 0 (start) 557 and 0 (start), then hold interrupt it will beep 5 times and shut down, this will turn off the calibration and allow you to make copies but will not improve quality.
Aug 06, 2009 | Office Equipment & Supplies
My toshiba e-studio 550: service recommended for SPC appeared
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
Jun 02, 2008 | Toshiba Estudio 200L Copier
Toshiba T-6000 Toner Cartridge for Use in Estudio 520 600 620 720 850 - 6, Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
