Question about Hardware & Accessories
What does COM. mean
Which wire goes to COM
  • 5,245 Answers
Copy following links to identify timer manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
http://waterheatertimer.org/images/orbit-connections.jpg
Do not connect voltage to COM and Pump terminals... these terminals have 24Volt AC output when timer turns ON. When timer turns on, then 24V flows to Relay. This action causes electro-magnet to turn on the pump.
Also do not connect power to rain sensor terminals. The rain sensor plugs into outlet, and produces 24V ac output. When rain sensor activates, then timer will automatically bypass the watering schedule until rain sensor resumes power output to timer.
Gene
Posted on Jul 25, 2013
I need the wiring diagram for a Nordyne GS3BA-024KA condenser
3 wires for compressor, 3 for fan. 2 comp. wires go to the top of the contactor, the remaining goes to herm terminal on capacitor. 1 fan wire goes to the top LEFT of contactor, remaining 2 go to com and fan on capacitor. You will then have 1 wire left that goes to the com on the capacitor and should go back to the top RIGHT of the contactor. NOTE: IF YOUR FAN MOTOR IS RUNNING BACKWARDS (MEANING AIR IS NOT BLOWING OUT OR UP) swap the to fan motor wires on the capacitor (fan and com) this should reverse rotation. ALWAYS REMEMBER TO TURN POWER OFF AND DISCHARGE CAPACITOR BEFORE TOUCHING WITH INSULATED SCREWDRIVER. Good Luck!
Apr 22, 2017 | Heating & Cooling
What number goes to what color wire
It doesn't work that way! What make/model of fan do you have? How many wires on capacitor? Usually the black wire goes into the L. Always write that info down BEFORE removing the wires & never cut the wires. Also, you have to get the correct switch. Just because it looks the same on the outside doesn't mean it's the same on the inside.
May 24, 2016 | Dryers
Check engine light is blinking and beeping
lost the operators guide, ?
it answers that.!
all OBD2 cars from 1996 do that, not beep , the blink
it means you are burning up your CAT converters.
when the EFI system goes hey wire, (means lost control of fueling or spark) it goes rich, and rich burns up cats.
the flashing means, get cars serviced NOW.
so you dont need $1000 parts.
here it is, if lost
posted 100 + times.
100% free
http://www.jeep.com/en/owners/manuals/
RTM it there.
or get it serviced like the 99% do.
or if 1% ,scan it next.
the tool is cheap,
Feb 26, 2016 | 2011 Jeep Liberty
Can't locate where it goes already off trans 2005 dodge two wires
Not enough information here. What do you mean by your question goes already off trans two wires. For what and where and for purpose?
Jun 06, 2015 | Dodge Cars & Trucks
Turn a corner and the hooter goes off!
I assume you mean the horn. This sounds like a wiring problem. You may have a wire that has lost the insulation, either by rubbing or by rodents. When you go around a corner, the wire shorts to either another wire or come grounded metal which sets off the horn.
Mar 04, 2014 | Volkswagen Golf Cars & Trucks
I have a Ruud Air Conditioner and need to install a new capacitor, but I forgot how the wires were on the old one. Can you help me in tellilng me which wire goes where.
There should be 3 terminals on the capacitor marked "C" "F" and "H".
A wire from the high voltage contactor goes to the "C".
Another wire from "C" goes to the compressor.
These wires are usually red.
The "F" terminal has a wire going to the fan,usually a brown wire.
The "H" has a wire going to the compressor,usually yellow.
There should be a wiring diagram on the control box cover identifying the terminals,colors and number of wires.
Jul 25, 2011 | Heating & Cooling
What does "hard start" mean
The compressor is having trouble starting. You can wire in a hard start kit to help the compressor start. Its easy the hard start has two wires one goes to Common on the capcitor and the othe goes to the HERM terminal on the capacitor.
Jul 19, 2011 | Heating & Cooling
Goes off 2,3 times by hour for few second and start again
If you mean the power goes off, you should get your equipment replaced.
If you mean your wireless connectivity goes off, I would check for interference from wireless networks on the same channel in your neighborhood, using whatever "stumbler" tool is available for your OS.
If you mean your wired connectivity goes off, it points to either a router equipment problem or an ISP availability problem.
Jul 01, 2010 | 2wire 2700HG-B Router (2700HGB)
Vrcd400-sdu
top row, left to right;
ground,memory,panel light,rear left spkr -,f rt spkr-, f lt spkr -, empty.
bottom row;
ylw batt +, red batt +, empty, rrspkr +,rlspkr +,frspkr +,flspkr +, empty.
Sep 17, 2009 | Cars & Trucks
Hardware & Accessories Logo
50 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
