Question about Innotek ADV-300P 200 Yard Rechargable Advanced Trainer
Reproggming innotek ADV-300P
Trying to pair receiver & transmitter. Have removed batteries in transmitter and tested but don't remember for sure how they aligned.
2 Suggested Answers
p_l_ross
  • 20 Answers
SOURCE: Innotek shock collar
I had same problem with an Innotek Bark collar. However after my dog s barking caused shocks the first times he wore it and quickly he changed that behavior. It finally and quickly got to the point that I still used it on him but I never had batteries in it as just wearing the collar was enough to stop his annoying the neighbors. These collars do not have a long lifespan like most electronic goods.
Posted on Jul 05, 2012
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
Motherboard connections (to front panel)
remember the colored wire is +, the + and - should be printed very small on the board near the connectors as well as what they are example (HDLED is hard drive LED) or (PWRLED is power LED) or (PWRSW is power switch) these are examples yours may differ slightly
Jan 31, 2013 | Gateway (4000811) Motherboard
Jul 01, 2012 | Innotek Pets - Others
GE audio/video switch AV93294 has what appears to be a adapter port on front , no voltage given. Says audio output. Please explain
As the label says, it's an audio output. The audio from whichever source you have selected appears at that jack so you can plug in something like a pair of headphones or the cable to a wireless headphone transmitter. If you don't have anything to connect there, don't worry about it. It's a convenience, but you don't need to use it.
Aug 14, 2011 | Audio Players & Recorders
My Sigma wireless dts 1606 L is not getting a consistent signal between the transmitter and the receiver. For example to day I rode 60 kms and the computer only worked / received 2kms worth of signal -...
It's a matter of good line of sight and distance between the transmitter and the receiver. Yours may be on the hairy edge of too far. Remove the receiver and test it at various proximities to the spinning wheel when it's transmitting.
May 22, 2011 | Sigma Sport BC1106 Dts Wireless Bike...
1982 Yamaha XJ 550, the battery will not take a charge. New battery, checked all connections, ran all the tests (stator, brushes, and alternator). Replaced the voltage regulator/recifier. Not sure what is...
It is corrected properly, right? + to the wiring harness and - to ground ... right? Are you certain about the rectifier? Is the battery charged at this time?
You know a alternator cannot make power unless you first put power into it ... right? Alternators (unlike most generators) are not self exciting. If your battery is weak or "dead", the alternator cannot make electricity to charge the battery. I don't know what the rating of your alternator is. Your battery should be fully charged before you do any more tests. If you have a 1 amp charger, allow at least 10 hours for a full charge. Don't cook your battery with a big, powerful, fast charging automotive battery charger.
Good luck with your repair ... I hope you find this response helpful.
Thanks for your question @ FixYa.com
May 02, 2011 | Yamaha XJ 650 Motorcycles
I need a manual for trouble shooting my Innotek Model 024101 electronic dog fence.
Innotek has manuals free for the download on their site. Your model number should actually be SD-2100 - the part number 24101 is for the transmitter only. That said, this should be the correct manual. If not, call Innotek at 1-800-826-5527.
http://www.innotek.net/Innotek/files/91/91bd9b70-6d16-4122-8ebb-86db65d904aa.pdf
Jan 28, 2011 | Computers & Internet
How to make my rear speakers wireless wat do i need
If you are considering using bluetooth for this, you will need a transmitter and receiver for each speaker pair. Each speaker pair will need to be driven by an amplifyer which interprets the bluetooth signal and drives the speakers. So for a 5.1 sysem, you will require 3 amps, 3 transmitters and 3 receivers. Also the power packs for charging the transmitters & receivers. Jabra make a very nice transmitter which I use, Its an AS 120S;. The 'S' is for stereo. For receivers I use a simple cheap unit I got off eBay. Item number 320519321206, which is a better unit than the Jabra. You have to have all signal through bluetooth (or none) because of the few milliseconds delay this technology produces.
Apr 18, 2010 | Samsung Audio Players & Recorders
I have a problem with opening car doors with remote for 1997 pontiac sunfire. I noticed that when you are in the car and you activate the open and close switch from drivers side the locks at the rear open...
Try this procedure...
KEY FOB PROGRAMMING INSTRUCTIONS
Transmitter Programming
No Tools Required
In the event that a transmitter is lost, program the old & the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If u program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver is seat. (actually it’s much ezr from the front pass seat)
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle is doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body & Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open & then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If u do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press & hold the transmitter LOCK & UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body & Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation
Hope this help (remember comment and rated this).
Apr 16, 2010 | 1997 Pontiac Sunfire
Reprogramming innotek RR 300S collar/transmitter
My dogs shock collar worked fine for about a year...now it's not! We changed the transmitter batteries and the dog collar batteries..no luck.
The model #M024801LF and the mfg date is 39588
Apr 28, 2008 | Audio Players & Recorders
Innotek ADV-300P 200 Yard Rechargable Advanced Trainer Logo
70 people viewed this question
Top Innotek Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Innotek Exercise and Fitnes Expert? Answer questions, earn points and help others
