Question about Refrigerators
HAVE SAME TYPE REF BUT WILL ONLY GET TO 40 IN ICE BOX AND 0 IN THE FREEZER THE DISPLAY CHANGES BY IT SELF
WHATS WRONG ONLY GETS 40 IN THE REF 0 IN THE FREEZER FRONT PANEL CHANGES BY IT SELF
    Sergeant:
  • 308 Answers
Test temperature with thermometer if more than 5 degrees difference change temp sensors
Posted on Jul 26, 2013
SOURCE: MAYTAG REF PROBLEM
Defrost timer curcuit board.
Posted on Mar 12, 2009
  • 72 Answers
SOURCE: ref. and freezer start getting warm and ice
defrost timer or bimetal cut off will need to be checked
Posted on Jun 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GC5SHEXNQ02 Whirlpool 2door ref - Panel gets hot
I am not going to say the problem is normal. Normal operation those strips are placed behind the metal and inside the walls around the door seals to prevent moisture or sweating around the doors. They are usually noticed to become hot when there is a change in the control boards operation. Some brands have the hot gas from the condenser circulating around the doors. If your model has an economy switch, switch it on. I would look for any abnormal operation of the refrigerator like compressor or condenser fan stopping or ice buildup or abnormal temperatures in the fresh food compartment. If this continues I would unplug the refrigerator and open the control panel inside the fresh food section and examine both sides of the control board for signs of heat or burn marks on both sides. May not be anything to be concerned about also because this may be the first time you noticed this. But it should not be too hot to touch. Sea Breeze
Posted on Jun 23, 2009
woodchuck789
  • 4070 Answers
SOURCE: freezer temp. set at 0, but only gets down to 12.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Mar 01, 2011
oldTech2332
  • 2341 Answers
SOURCE: Ge moogram Model# PSB42YSXSS The first time I went
Hey Rkraft,
i may have answered that question in the comment ya posted on the other Monogram
But now as i think about it how is the frost pattern on it is part of the evap coil covered in ICE (not frost) that could be a sign of a sealed system problem but only if part of the evap coil is iced up and the tube i spoke about on in that other comment isnt frozen
GENE
Posted on Oct 15, 2011
W have a amanda ref model AF12538AEW SER#12987374LX putin to storage a year ago. Worked fine. Pulled it out of storage. Freezer get 34deg. Ref 40 deg. Any thought whats wrong?
THE UNIT HAS MOLD BUILD UP IN THE EVAP COIL IT NEEDS TO BE CLEANED PROPERLY BY REMOVING THE FREEZER RACKS AND THE SCREWS IN THE REAR OF FREEZER COMPARTMENT THEN USE HOT SOAPY WATER IN A SPRAY BOTTLE AND CLEAN THE EVAP COIL AND MAKE SURE THAT THE DRAIN TUBE ISNT CLOGGED REINSTALL PARTS THEN TURN ON BOX CHECK TEMPARATURES. FOOD AND MOLD GETS INTO THE EVAP COIL AND MOVING DOORS AND FLAPS AND AIR PASSAGES CLEAN UNIT WITH HOT WATER AND BLEACH MIXTURE TO KILL MOLD SPRAY OUT ENTIRE BOX WITH MIXTURE OF SOAP AND BLEACH WATER AND RINSE COMPLETELY
May 04, 2015 | Refrigerators
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
Fridge freezing up
Set your Ref/Freezer per the following:
Refrigerators:
36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
You have to wait about 4 hours for everything to stabilize. If you are still having ice forming inside the freeezer then the rubber seal around the door is probably the problem. If they have a split, tear or crack, etc. it will let warm moist house air into the freezer and turn to ice as it cools. If this happens in the refrigerator it'll turn to water and collect in the bottom of the frig. New seals can cost around $60 per door.
If you pack too much food in the unit it may also cause freezing because the air needs to move around in there and food shouldn't block the vents in the back walls of the unit.
Hopefully this helps..
Nov 23, 2012 | Spartan Showcase Self Service Cigarette...
Freezer works. 0 degrees ice box only gets to 40 degrees
no1 check the thermostat 2 check gas 3 is compressor working
Nov 20, 2012 | Refrigerators
The vegetables in the vegetable drawer freeze. the freezer registers 0 degrees and the refrigerator 40 degrees
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 21, 2011 | LG LFX25960 Bottom Freezer French Door...
Freezer side where ice maker is located and the ice gets dispence is freezing up
Leo Ponder
imufo2
Sep 21, 2011 | Whirlpool Refrigerators
I BOUGHT TRIPLE DOOR WHIRLPOOL PROTON FRIGE.VEGTABLES KEPT IN VEG BOX GETS FREEZED. ALREADY CHANGED TRMOSTART ONCE . PLEASE GET ME A SOLUTION
Leo Ponder
imufo2
Sep 19, 2011 | Refrigerators
2007 french door -bottom freezer -kenmore elite fridge- freezing foods in fridge and icemaker not making ice regularly- sporatically making small amounts of ice cubes motherboard was replaced when fridge...
Leo Ponder
imufo2
Sep 14, 2011 | Refrigerators
I have a top refrigerator bottom freezer model # JFC2087HRS no ice maker my freezer only gets down to 26 deg F the refrigerator is about 40 deg. F
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
If
you need more help go here:
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 20, 2011 | Jenn-Air JFC2087HRS Side by Side...
40 TO 50 DEGREE IN SIDE REG/ FREEZER 32 DEGREE IN FREEZER. HOWEVER CLEANNING RESET DAILS BRING US 10-0 DEGREE FREEZER/ REF 32-38 DEGREE IN REF. THIS REF WILL NOT SABLE ITS SELF. WINTER TIME NO PROBLEM/...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Hotpoint Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
