Question about Black & Decker ProFinish X750 Iron
Power cord Special tool for the screw required?
How do you repair the retractable cord on a 1500w iron
So many people make a copy of that iron maybe a local repair shop for tefal, black n decker, or another can do it. Taking things apart sometimes is not worth the trouble of putting back together. sometimes it requires special tools. call around first before you try it yourself
Jan 26, 2015 | Rowenta DW2090 Effective Comfort Cord Reel...
Replace power cord. Has special screws on back plate torque screw driver won,t fit.
I am not familiar with your particular iron ... however, I am familiar with different types of "bits" I suspect yours are security "Torx". Torx look like a "allen" with points. Some call them "star". A Torx 'security' will be the star shape with a pin in the center, disallowing a regular Torx bit from entering. If you will take your Iron to the Hardware Store or your local Auto Parts store and show to the salesman, I am certain they can sell you the proper bit to remove the cover on your Iron. You may have to purchase a handle at the same time.
There are other types and yours may not be Torx. It could be any of many including a thing that looks like a philips but only three slots instead of 4 or a 'clutch' or it could be a 'one way' or other special bit.. The person at the store should be able to identify the appropriate tool immediately. If not, there are probably more than one store in your town ... go to he next and so on until you get the necessary tool.
Thanks for your question today @ FixYa.com
Jun 05, 2011 | Rowenta DZ1700 Iron
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
No power from cord. I want to replace the cord.
In replacing the cord, you have to remove the screw that holds the back cover and unscrew the damaged cord from the heater terminal. Insert the new cord on the rubber insulator and screw it to the heater terminal.
Nov 04, 2010 | Euro-Pro Shark GI490 Iron
My iron is a Black & Decker model with a short circuit in the cord, I need a special screw dri8ver to open the Iron where can I purchase this screwdriver?
any auto parts store with selling tools should have the tool you need take the item down and have them look at it so they can get you the right one.
hope this helps
Sep 01, 2010 | Irons
Rowenta Iron-Professional Luxe The power cord seems to short out when you move iron. You can wiggle it next to the movable ball and it clicks on and off. The two screw heads on bottom appear to be special...
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Oct 22, 2009 | Rowenta Irons
Iron won't stay running. I'm pretty sure it's the cord because if you move the cord the power is restored. Would a new cord solve the problem and where do you get a new cord?
With modern iron it can be difficult to renew the cord due to the special screws they use when making them. It does sound like the power cord is damaged. It may be cheaper to buy a new one from wallmart or similar store.
Jul 29, 2009 | Rowenta DX6700 Iron
The cord on my professional Luxe has a short near the handle.
Take your iron to a hardware store and they should be able to guide you to the tool that you will need.
Feb 13, 2009 | Rowenta Professional DM890 Iron with Auto...
Black & Decker ProFinish X750 Iron Logo
47 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
