LEXMARK PRINTING PROBS
Everytime I try to print something the printer gets to 40% and stops. Sometimes if you log out and Log in the printer prints the page but not always. I have had this printer for ages with nothing wrong until now
    Problem Solver:
  • 13 Answers
Hey you can get cheap ink cartridges if you want with full guaranty.
Posted on Aug 09, 2013
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
mediatecar
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
Posted on Aug 19, 2008
  • 76 Answers
SOURCE: printer keeps printing blank pages non stop going
drop kick unit across room:)))) sorry just kidding I had the same problem with mine. If the computer is continually printing that means the printer is receiving print orders from your computer. Best thing is just disconnect the printer from the computer and turn the computer off and wait 30 seconds then turn on . This should clear the print cache then reconnect the printer. Make sure to only request one print at at a time.
if the printer continues to print blank pages check to see if you have the latest software driver for the printer installed on your computer. You can do this by going to the manufactures website and download the software its easy to do just follow the prompts and install! Hope this helpful!!!
Posted on Jul 24, 2010
  • 39 Answers
SOURCE: I get blank pages when printing. Sometimes all pages are blank, sometimes first and last page print, with blank middle pages.
1. Try cleaning or replacing your laser scanner mirrors.
2. Make sure that your transfer roller is seated properly.
3.Update your printer driver.
4.You might have failing power supply, make sure that the drum ground spring is connected to the engine controller board properly. You can also replace your high voltage power supply.
Hope this helps.
Posted on Dec 29, 2012
I have an MG2200 Pixma printer. It stopped printing in the middle of a delayed queue because it ran out of paper. I put the paper in and then I think I turned it off and then on again. It will not...
Log off your computer so it shuts downs.
Log back on
Go to control panel
-Find Printers
-Click on Printers
Plug your printer into computer
-Printer should show up on screen
-Right Click on Printer and set as default
-Left Click on printer
-Click on see what printing
-Cancel job that's printing
Close printer
-Try to print again
Nov 02, 2013 | Canon Office Equipment & Supplies
How to print fax log
try this
* Press Setup menu (setup button) on the printer.
* Go to the second option print Report.
* Select the 6th option Fax log. Press Ok.
* The fax log will print now.
Apr 16, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark z31 printer will not stop printing
Disconnect printer cable from PC. Power off printer and unplug power cord from outlet. Wait 15 seconds. Press the power button as if to turn on with unit still unplugged. Plug back into outlet and turn on printer.
Before reconnecting to PC, check the printer's queue status. Start, Control Panel, Printers. Select the printer by double clicking to open queue status. Select any remaining documents and choose cancel from document menu bar.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Lexmark Z31 InkJet Printer
Everytime I print a document it prints out a Printlog, how can I stop this
Go to your printer control panel and look for log printing. You can change the value there and exit.
Sep 12, 2009 | Brother HL-5240 Laser Printer
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
kw7157@yahoo.co.uk
Mar 20, 2009 | HP LaserJet 4100 Printer
Lexmark x9575 wont print with Windows Vista
buy a different printer i had problems with my lexmark even got them to install drivers via remote they couldnt do it so i bought a cannon worked first time and everytime
Mar 03, 2009 | Lexmark X9575 InkJet Printer
Printer printing backwards on two users but not the main one
Compare the default printing preferences (Start>Settings>Printers and Faxes) Right-click on the printer icon and select Properties and Printing Preferences. Look for the option to print Mirror image used for printing T-shirt Iron-ons and uncheck the box.
Jan 03, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
20 people viewed this question
jasbo
jasbo
