Question about RCA 24" LED 1080p HDTV LED24B45RQ - ON Corp US, Inc
Icon on screen won't go away...
I have an RCA TV/DVD combo that I'm using in the kids room, and an icon of a movie camera with "1/2" is on the screen on a few DVDs, and will not clear. I've read the manual front to back, and pressed every button to clear it off the screen to no avail. How can I delete it?
dave1645
  • 834 Answers
SOURCE: RCA tv dvd combo L26HD35D programming codes
not gonna happen
Posted on Sep 20, 2009
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
budmrtn
  • 11361 Answers
SOURCE: RCA L32HD35D TV/DVD Combo has sound but black
I may have lost the 24vdc power supply or the backlight inverter board shorted out or not getting the ON command to the inverter, please read my guide to understand how LCD TV works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 03, 2010
muntejaya
  • 10421 Answers
SOURCE: Disable DVD Region Code
Hi, kindly get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__x342w
Posted on Feb 27, 2011
  • 8457 Answers
SOURCE: Just got an RCA TV
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Posted on Apr 24, 2011
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
RCA L32WD26D TV/DVD/HD Combo - dvd wont eject
Hello
Check the loading motor and loading belt. If loading motor has damaged, or loding belt has broken or loose. the in-out tray mechanism won't work well.
Mar 03, 2012 | RCA L32WD26D HDTV/DVD Combo
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
Dec 24, 2011 | RCA TruFlat 27F520T 27" TV
I am able to get in with the 5898 code to unlock the tv, it won't let me put in a new code and I still can't watch r rated movies? and when I get in to the dvd side of things it only want's 3...
Hello
Just unlock it following any one of the methods described below. Then reset it as your desire. One amoung the following methods will surely unlock your RCA and give you option to do others.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
May 17, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
RCA D52W136D 52 in. TV/DVD Combo dvd does not play
did you try to get a dvd cleaner to clean out your dvd player.
Feb 13, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Trouble splitting display with NAV in front and MOVIE in back
PRESS AV BUTTON ON BOTTOM .
PRESS UPPER LEFT CORNER ICON.
LOOK FOR "REAR SCREEN" ICON LAST ONE 2ND ROW.
PRESS THIS ONE A COUPLE OF TIMES TILL IT SAYS DVD.
DONE
Oct 03, 2009 | Pioneer AVIC-Z3 Car GPS Receiver
IDVD movie opens before menu when played on DVD player
In your iDVD project go into the DVD Map menu.
(Little flow chart like icon in the bottom-middle of the iDVD menu screen.)
Look for the very first icon in the map. (Upper left)
This has a small DVD symbol and a play icon on it.
Delete this icon.
Re-burn your DVD.
The menu should be shown first now when you play the DVD.
Jun 28, 2009 | Apple iLife '09 Mac Family Pack - APPLE -...
Fisher price kid tough camera shows red-yellow-green light icon with an arrow on the red. Also the flash icon (lightning bolt) is showing in the bottom left of the screen. Emptied memory and changed...
We had the exact same problem. We transferred the photos off of the camera and then it went away. So possibly it is a memory full error or a card read error. I am not sure but the transfer solved the issue.
Jun 23, 2009 | Fisher-Price Kid Tough Digital Camera
Locked Tv blue screen with Lock icon lower left corner
Hold down the tv call button on the remote for a few seconds and it should unlock.
Oct 20, 2007 | Televison & Video
RCA 24" LED 1080p HDTV LED24B45RQ - ON Corp US, Inc Logo
144 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
