Question about GE Microwave Ovens
GE microwave: start button doesn't work.
Control panel of GE microwave countertop oven JE-69 got damp from sponge. Heat and dowel pressing has removed moisture and all buttons work now except the all important "start". button. Have applied suction from vacuum, heat from hair dryer and waited for dry-out. Is start controlled with an SCR or relay, are there fuses I should check inside? Unit assembled April 1987, Louisville.
MicrowaveSvc
  • 9085 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
rhozel2010
  • 269 Answers
SOURCE: microwave won't heat. turntable works control
Hi! check the fuse that goes through the magnetron because i think it is no functioning.
Posted on Sep 12, 2009
heatman101
  • 43501 Answers
SOURCE: My GE Profile Convection Microwave Oven - Convection not working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uijjf
Posted on Sep 30, 2010
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave refuses to work when
That's probably a failed door switch or door switch mount.
It's a pretty simple do it yourself fix. See this helpful file on door switches.
You can find handy exploded views and order parts by model number here.
But if your cooktop lights failed recently, you have a damaged control circuit board, which we can usually repair for $39.95. Details are here.
Posted on Jan 11, 2011
espressonist
  • 1711 Answers
SOURCE: JNM 1855 Microwave oven is
The description of the sound lead to burn of the high voltage diode part no 50. Alsoafter this the fuse will also blow out part no 47 at the parts diagram.
In anycase their will need also diagnostic to confirm the diode and fuse or any other parts.
Posted on Aug 15, 2011
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
I have a Miele h5080bm microwave oven. How can I clean the grease of the roof and sides of the microwave?
You can put a microwave safe bowl of water in the oven and heat it to boiling, stop the microwave, then leave the bowl of water in the oven for about 10 to 15 minutes. The steam will loosen the dirt and grease and then it can be wiped with a damp sponge. More stubborn grease my need dish soap on the sponge and a little more elbow grease. Rinse it well with a clean sponge or dish cloth and warm water.
Feb 15, 2013 | Microwave Ovens
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
Jun 25, 2012 | GE SpaceMaker Microwave Ovens
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
Won't heat or cook. Has power, light and clock work, Fan comes on when you push cook button but the carousel doesn't turn and it doesn't cook
heatman101
jhfjk
Jun 29, 2010 | GE Countertop Microwave Oven
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
My ge profile microwave oven sometimes turns on when door is clos
hi and wellcome to FixYa this is a comon problem with the control unit for the microwave being damaged the buttons start to stop working more or few buttons at a time, there are companys that sell the front units seperate for these microwaves but can cost more than a new microwave itself , the unit itself is damaged by heat from the microwave or on rare accasions damp im sorry there is no other way to sort this apart from a new front control unit or a new microwave
Thanks Hope this helps a little
Feb 06, 2009 | Whirlpool MH7140XF Microwave Oven
Deep hard core cleaning
From GEAppliances.com: Microwave - Cleaning Recommendations To minimize the possibility of electric shock, unplug the microwave from the power supply before attempting any maintenance or cleaning. Spills and spatters clean up easily with a damp, soapy paper towel or sponge. It is best to clean soil as soon as it appears. Baking soda and water may also be used. If the food has cooked onto the interior, heat one cup of water on full power for three minutes. The heat and steam help to soften the food. After the three minutes, allow five additional minutes stand time then clean as usual. A non-abrasive scrubbing pad cleaner works well for stubborn stains. You may use mild dish washing liquid or cleaners specifically listed for cleaning interiors of microwave ovens such as MicroBryte® (wx10x3030) or Microwave Oven Magic®. We do not recommend using other detergent based cleaners because they can cause the plastic parts to crack. You may purchase microwave interior cleaner by calling our parts department at 1-800-626-2002, on-line from GE Parts or from your local grocer. For stainless steel interiors of microwave/convection models, we recommend a plastic, soap-filled scouring pad. Rubbing gently with this pad will help remove soil. For the door surfaces (both interior and exterior) We recommend you use only mild, non-abrasive soaps, or detergents applied with a sponge, or soft cloth. For the control panel Wipe with a soft, damp cloth. Dry immediately with a soft cloth. Do not spray any solution directly onto the controls Important: Commercial Oven Cleaners, abrasive cleaners, or cleaners containing ammonia or bleach (can make the plastic brittle) should not be used on any part of the microwave. -- From me - Maybe local restaurants in your area would have some tips? Otherwise, try a Google search for keywords: cleaning stainless steel oven
Aug 05, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
94 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
