Question about Jensen VM9510 Car DVD Player
Dual audio XDVD700
Will this work for a XDVD700 if not where can i go n get that bypass code
  • morganzach Nov 15, 2007
    my dual xdvd700 will not play mpeg files is there anyway to make them play or is this permanent????
  • tammi01 Dec 26, 2007
    i want to know where can i get the brake lock-out code
I have a problem for some reason the touch screen is not working when i touch it any more dose any one have a solution to this???
Posted on May 16, 2008
My screen says decoding error. and plays music when it wants to..
Posted on Apr 17, 2008
In order for you to see the movie ( refering to XDVD700) you have to hook up that yellow wire in the back of your radio to a ground. Here's the thing though, the radio senses if the wire is directly connected to ground when the car starts up or is in accessory. So in order to syke the radio out, is to put a switch in between the yellow wire that you have connect to ground. First, turn you car on or put the key to accessory, then after it has turned on, you then flip the switch. If the radio senses ground from the ground wire and yellow wire at the same time it will not show the movie and leaves you only with the audio from the movie. Hope this was some help and i didn't confuse you.
Posted on Dec 13, 2007
This inability to play mpeg files, sounds more like a codec (digital key the player uses to decode the file for video playback)issue. Only specific files with the proper encoding will function. You may look into DIVX encoders, which seem to be the standard for this player. Make sure the version of DIVX matches, or you may still run into this issue with them.
Posted on Nov 30, 2007
I can hear my player but can not see anything
Posted on Nov 27, 2007
3 Suggested Answers
SOURCE: Dual audio XDVD700
Try playing a DVD Press Stop Twice Enter 26604 Press Enter
Posted on Feb 23, 2008
SOURCE: how do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Posted on Jun 13, 2008
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
I have a xdvd700 dual and want to bypass the brake thing but no remote is there anyother way?
Usually there is a handbrake connection that needs to be grounded to the chassis in order to bypass the screen lock. I normally wire it though a switch to ground and back to the handbrake, so if the car is inspected it works like it should.
Some units feature a footbrake wire that needs to be pulsed as well. This is harder to override. I use a bypass device from Peripheral called the PAC-TR7.
Dec 06, 2009 | Dual Electronics XDVD700 Car DVD Player
Dual xdvd700 has been locked, broken remote, blue screen
you have to press the reset button then it will work
Sep 17, 2009 | Dual Car Audio & Video
Video bypass for dual xdvd700 without remote
i used a switch, to the ground, and i'm still having problems, so yeah lol
Jun 17, 2009 | Dual XDVD8181 Car Video Player
Dual xDVD700 won't come on
CHECK VOLTAGE ON RED AND YELLOW WIRES OR RESET THE UNIT.
May 13, 2009 | Car Audio & Video
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Aug 26, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Any luck on that dual xdvd-700 code?
what is the code for the dual xdvd700
Mar 26, 2008 | Car Audio & Video
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
Dual audio XDVD700
Dec 21, 2007 | Car Audio & Video
Jensen VM9510 Car DVD Player Logo
510 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
