Question about Cell Phones
Iphone 3 battery not charging - Cell Phones
    Master:
  • 435 Answers
Syed,
I am pretty sure in most of the cases there is a problem with the charging port of the phones. You can switch the battery with a friends or family member s iphone 3 and see if the battery charges in their phone. If not then the battery is dead and you need to buy a new one. If it is charging in other devices then your charing port where you insert your charger is faulty. I hope this helps :)
Posted on Jul 25, 2013
After one hour the battery was empty even the battery full charge it.
You phone needs a new battery. They last 2.5 to 3 years in normal service. If your phone is newer than that, you may be able to get a warranty repair. My iPhone 7 will play music non-stop for about 3 days on a charge.
Jan 04, 2017 | Cell Phones
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
IPhone Smartphone: my iphone is not turning on...
1. Try a full charge using a wall socket. If it's a dead battery you should see the battery charging screen after 10 minutes or so.
2. Connect to your computer. If you hear an audible beep and/or iTunes recognises the iPhone then it looks as though your touch screen digitizer display is dead.
3. If none of the above then it's probably a more serious internal problem - likely the logic board - and if out of warranty it will be expensive, but not prohibitively so, to fix. I'd suggest checking out ifixit.com for parts and repair guides or contact an experienced repair center.
May 17, 2010 | Apple iPhone Smartphone
IPhone Smartphone: cant charge iphone in ibiza battery went flat...
Possible solutions
1. buy an adapter for your charger
2. plug it into a computer
3. provide more details than you have so far...
can't charge iphone is a vague way to explain your predicament...
can't charge or won't charge?
can't get an adapter?
don't have access to a computer?
Half solution, half clarification request...
May 16, 2010 | Apple iPhone Smartphone
Battery life less than 12 hours; Wifi says "UNABLE TO CONNECT"
This is a really good article that will take you step by step through the settings that will best optimize your battery life. And if this doesn't help you should make an appointment at your local Apple store, they are always very helpful (at least in my experience).
http://www.apple.com/batteries/iphone.html About iPhone BatteriesLearn how to maximize the lifespan and battery life of your iPhone.
Nov 09, 2009 | Apple iPhone 3G
Iphone Battery died now it wont charge or turn on
Hello ! I was in panic attack !!! did everthing and nothing seems to wake up my iphone. I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!! How I fix it?
1-unplug it from the wall charger 2- press middle button and startup button, same time 3-when red battery dissapear, plug the charger. 4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!! GOD BLESS YOU ALL !!!!!!!!
Aug 21, 2009 | Apple iPhone Smartphone
IPhone - mice not working
hiiii sir plz give me solution my iphone mic is not working ,voice is incoming but my voice is not going
Apr 15, 2008 | Apple iPhone Smartphone
Iphone won't charge and now won't work
I left my phone charging for a few hours and it appeared not to be charging as the battery icon was staying at 10% of charge. I was confused because it had the charging icon in the upper right hand corner. If your phone is doing something similar i simply powered the phone down and turned it back on. The charge went from 10% to 100% on the display. This is what worked for me hope this helps.
Jan 22, 2008 | Apple iPhone Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
