Elonex Xv-S Factory Reset Garbled Screen
Hi, I have Elnonex Xv-S TV. It has following buttons: Volume Down, Volume Up, Menu, Channel Down, Channel Up and Enter. Please could anybody tell me which order do I have to press them to reach Factory reset? The TV screen is garbled. There is no remote. Thank you!
  • David Sep 13, 2013
    Unplug the TV and leave it off for a week or two.
    Alternatively press Menu 1x, Ch Down 2x or 3x (depending on source selected), volume + 1x, Ch Up 1x and Enter. This will reach reset on Settings Tab.
SOURCE: viewsonic n2751w
why does my 27 inch lcd monitor keep changing colors
Posted on Jan 04, 2008
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
SOURCE: need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Posted on Mar 28, 2009
dsacco86
  • 1077 Answers
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Posted on May 29, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
Hi do you know how to hard reset PM-0510-BV
From the home screen, press Menu - Backup and reset - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
if you can not access this area you can proceed with the following.
This will remove all data from your device and set it back to factory defaults.
While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select
Your phone will restart and may take several minutes to come back up.
Nov 21, 2014 | Office Equipment & Supplies
Toshiba 20A22 the kids took the color out of the
Don't try to reset it to factory. That will cause you more problems that will be harder to fix, especially with no remote. (Rhetorical question: Why do so very many people lose their TV remotes. How does that happen?)
Press the Volume Up and Down buttons at the same time. This will display the on screen menu. Release the buttons when the menu is displayed.
Now press the Vol Up button each time to advance the menu until the word 'PICTURE' is displayed. Press the 'CHANNEL down / ENTER' button to select this part of the menu.
Now press the Vol Up button each time to advance the menu until the word 'COLOR' is displayed. Press the 'CHANNEL down / ENTER' button to select this part of the menu.
To add color back, use the 'VOLUME up / Set+' key. To reduce the color, press the 'VOLUME down / Set-' key.
The user manual doesn't give a way to exit the menu, so my guess is that when left alone the TV will exit out of the menus itself on a timer. If not, try pressing Volume Up and Down together once more.
Sep 12, 2014 | Televison & Video
Remote has broken for my Elonex hdmi hd ready tv..
Probably.
Most TVs allow menu navigation using the channel and volume button as surrogate Up/Down and Left/Right. There'll also be a button that acts as 'Select/OK' to go in a menu level at a time.
Sep 05, 2014 | Televison & Video
Volume tv goes down its own
Depending on your TV, here are the generic steps Toshiba has outlined to reset your TV:
1. Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
2. Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
3. Highlight the SYSTEM STATUS menu at the top.
4. Highlight SYSTEM INFORMATION below and press ENTER.
5. At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
6. Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
Apr 09, 2014 | Toshiba Televison & Video
How do i get the parental lock off my set
Hello
To reset the parentian lock password in Vizio TVs do the following
* Get into it MENU and come towards Parential Controls window.
* When the MENU button is pressed, the On Screen Display (OSD) appears on the Image Settings page.
* Press the [Channel Down] button to change to the Parental Controls page.
* Press the OK button and the first of the 4 Password boxes will be highlighted.
* Press the [CHANNEL UP-> CHANNEL DOWN-> VOLUME UP-> VOLUME DOWN] buttons in this exact sequence. Press the OK button
* The password has now been reset to "0000" and the following message will appear.
You can reset it after. The above said buttons will be on the center of the remote control within a circle. OK.
Jul 11, 2011 | Vizio 42 in. LCD TV
Screen displays empty data base and cannot be re tuned
This sounds like a software glitch, you could try a factory reset, but you do so at your own risk. Here's how:
On top of your tv there is four buttons...
1...Turn your tv off
2...Hold down TO THE LEFT the volume button and the CHANGE CHANNEL button.
At the same time hold down the AV select button (round button)
3... Now press the tv ON button KEEP ALL THE BUTTONS DEPPRESSED untill the TV turns on...
4... By now the screen should have come on with a engineers menu on.
5... Using your remote scroll up and down the menu using the ""P"" button...on the menu you will notice items saying RESET..click either ""OK"" OR using the navigation buttons on your remote (thats the 4 surrounding the ok button"" press the right arrow then press ok.
6... Scroll through all of the pages ALL 11 of them and reset them all.
At this point your tv on/off button may not work..simple turn off at the socket and everthing should have been reset.
Now turn your TV off then back on again.
Hope this helps
TV_Doctor
Jan 05, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
