Question about Ames Safe-T-Deck Elastomeric Waterproofing Sealer Deck
Bubbles in my top coat.
I would like to know of a good way to get rid of bubbles in the finished product, I ended up with a couple of air bubbles and would like to know the best way to get rid of them.
  • 46 Answers
The moister that is trapped under the coating that is causing the problem may dissipate (maybe)
If not you will need to cut out the area with a razor blade and re-coat the area.
Perry Tradesman
Posted on Mar 21, 2015
How do you bleed clutch
I gravity feed my hydraulics first.
remove reservoir cap and then open the bleed nipple until you have fluid coming out - you need to make sure that the reservoir does not run dry.
once you have fluid coming out of the bleed nipple nip it back up and then do a normal bleed.
Pump the leaver a couple of times and whilst holding it in open the nipple quickly - you will see the air bubbles come out reapeat this process until there are no air bubbles at all coming out - you MUST continue to top up the resivour - if you don't you must start the process all over.
I use a piece of clear tub off the end of the bleed nipple as this allows you to see the bubbles easier as it holds the fluid and bubbles in the line.
May 19, 2014 | 1982 Honda VF 750 S
2004 fxst motor vibration and noise top end air bubbles on dip stick didn't change oil yet
Hopefully you are not saying you have 27000 miles on the same oil. If so lots of engine parts are likely worn out. nORMAL FOR SOME AIR BUBBLES TO APPEAR ON THE DIPSTICK WHEN HOT. This engine should not have vibration or top end noise.
Apr 23, 2014 | 2007 Harley Davidson XL 883 Sportster
Bubbles after 24 hour cure
I recently covered a wooden chair in epoxy resin. It is the nature of the product to create bubbles as it hardens. The directions stated to gently blow on the bubbles as they formed. Check it often and blow on any bubbles that form in the first 45 minutes after application. This worked quite well for me. Be sure to wipe up any drips in that first 45 minutes too, they are a pain to sand when they are dry!
Mar 19, 2014 | 3M Scotch-Weld Epoxy Adhesive DP125 Plus...
How do I get rid of bubbles in the top coat
The sealer using on concrete has to be stirred not shaken that might be a problem
Jul 25, 2013 | Ames Safe-T-Deck Elastomeric Waterproofing...
Air bubbles in sight glass but pressure is good
leak on intake line or bad seals in pump
May 08, 2012 | Hayward Pool & Spa
Getting bubbles after the nail polish dries
Make sure you let each coat dry completely before applying the next, air can get trapped between them as it dries
Jul 14, 2011 | Opi Nail Polish Chambord & Bubbles Ed...
How to replace a master brake cylinder on a 1989 oldsmobile 88 delta
First thing you need to do is bench bleed the new master cylinder.new master should have come with 2 plastic tubes and fittings.screw fittings into new master,fix tubes to fittings other end in to top of master where fluid goes.fill with fluid make sure the tubes are submergered in brake fluid for entire process.take a screwdriver and press plunger in rear of master.use short slow strokes to start you will see air bubbles in resovoir.slowly increase length of stoke watchin resovoir till no mome bubbles.now ready to install.Remove failed master,(loosen lines befofe removing mounting bolts)remove lines last.reinstall new master then remove bleeding tubes last install and tighten lines.Fill fluid replace lid,have a helper sit in car,loosen lines about half a turn.Have helper depress brake pedal slowly and hold down pedal untill lines tightened.when tight release pedal and repeat 5/6 times.fluid should come out of lines without any air when bled propperly.if failed master did not run out of fluid uyou should be finished.if pedal still soft/mushy will have to bleed a wheels also.use same proceedure but openening bleed screws not lines.may take many times to get rid of all air,you can see and hear the air exiting bleeders.keep an eye on fluid level while bleeding if u run out you are starting again
Jan 24, 2011 | Oldsmobile 88 Cars & Trucks
How to get rid of air bubbles
The water going back into the pool has air bubbles or?
Open the bleed valve at the top of the filter housing until just water comes out, be careful you'll get sprayed.
Check all the hose connection for tightness.
May 25, 2010 | Hayward EC-40 DE Pool Filter with pump
I am removing Formica and refinishing a teak wood yacht table. I got the Formica removed(no easy task) and I am wondering how best to go about refinishing this table. There is a little glue left(this table...
Clean the remaining glue off with naptha. If the table has no gouges, I would start with a 180 grit paper and work my way up to a 400 grit. You can use a polyurethane finis which can be satin or glossy. I prefer the satin, but you may want to experiment on a different pice of wood to see what you like. Use deliberate slow strokes when using a urethane so as not to induce air bubbles into the finish. If you want more than one coat, fine sand with a 600 grit between coats when dry and apply the next one. With glossy finish, the more coats the greater the visual depth appears to be.
Jan 19, 2010 | Air Tools & Compressors
2000 maxima overheating
You have a new radiator and thermostat, so your coolant was flushed. Was the radiator "burped" afterward to get rid of air bubbles? If not, that needs to be done first - it would explain virtually every symptom you're seeing.
Jack up the car so that the radiator cap is elevated. With the coolant topped off, start the car and let it run until it's about 3/4 of the way to overheating. Then shut it down and go have a beer. When it cools off enough to safely open the radiator cap, do so, and any air trapped in the system will bleed out.
What you're doing is circulating the coolant and the air bubbles inside. The bubbles get lodged behind the thermostat and stay there, keeping it from opening (this causes the car to heat up). When you later pop the cap off the radiator, the pressure is vented from the system, the thermostat opens, and the bubbles pass through. They'll work their way to the radiator (since you've got it elevated) and pop out the open cap opening.
Your coolant level will likely drop somewhat after doing this, as the air bubbles will be gone and the space they took up in the system is now available. You may need to add a little more coolant, so top if off (with the car back on the ground) and recap the radiator, fill the overflow to the marked point on the tank, and you're good to go.
Try this if you haven't already, and post back up with your results. If it doesn't solve the problems, we'll take it further.
Aug 11, 2008 | 2000 Nissan Maxima
Ames Safe-T-Deck Elastomeric Waterproofing Sealer Deck Logo
800 people viewed this question
Top Ames Adhesives, Coatings & Sealants Experts
David Payne
David Payne
Richard Piatek
Richard Piatek
Are you an Ames Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
