Question about Water Heaters
Deva revive 9.5 kw electric shower
Shower water still flows, can only stop water by turning of electric at the mains switch. one solinoid valve must work to stop water but the switch on the front seems not to deactivate the flow.which solinoid valve is faulty please or does the switch need replacing
SOURCE: Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Posted on Nov 29, 2008
gary1121
  • 332 Answers
SOURCE: adjusting water flow
if you are using a mixing valve it is pre set so as to not burn your self but if you wish to set it on the dial depending on which one you have, some are flat tip screw driver some have plastic cap on it turn on the water and set to your desired temp by turning clock wise or counter clock wise
Posted on May 30, 2009
gary1121
  • 332 Answers
SOURCE: Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Posted on Jun 06, 2009
  • 172 Answers
SOURCE: Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Posted on Jan 21, 2010
  • 14 Answers
SOURCE: Problem with valves in Grundfos hot water recirculation system.
Yes, you need to replace it.
Posted on Sep 30, 2010
Marey tankless hot water heater 16ng
turn down gas and turn down pressure switch
Aug 02, 2017 | Water Water Heaters
My family is moving in...how do i increase hot water availability?
large water heater, turn p the themo stat to a higher setting ( watch for burns with young childern and older folks)
or the best install a tempering valve. this valve mixs hot water with cold water before it goes into the building.
Again if you have young ones or old people they can burn faster than any other group.the best is a larger heater for the DIY person.
Thanks Tom
Sep 13, 2011 | Rheem Water Heaters
Shower goes cold intermittently like there is a restriction in hot water delivery. Plenty of hot water when it comes back, but the cold blast is not fun. No shortage of hot water for long showers or...
Has nothing to do with the expansion tank, the expansion tank whole enough air so that when the heater heats the water it does not build up pressure. You know from school that you can compress ait. you CAN NOT compress water. When you haet water it expands until it turns to steam. So lets rule that out.
First look at all the plumbing in the house where there is a cross conection. This would be like a shower valve that has a personal shower head on it. and you turn of the water using the personal shower handle and not the valve at the wall. This then would let cold water to go into the hot water side piping.
Most people do that with out knowing it at the laundry sink. they put a hose on to was the dog and forget to turn off the faucet and then BANG cold water in the hot side.
Go around the house and turn off all the faucets and valves by using the handles. no add on things.
Now last could be the shower valve itself. . Do this happen in just one shower or all of them???
If its just the one and you spend the day doing the walk around, even check the bidet if you have one
its the valve. you need repair to that.
Best of luck in your hunt Tom
Sep 08, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Hi, I just got my new DHC 10-2 today, the installation was easy but I have a problem. The problem is that heating is not constant. Once I mix the cold and hot water I should have an uniform temperature but...
This electric demand water heaters has one heater element. The flow switch turns it on. The thermostat cycles it on and off according to temperature. There is no medium.
You need to run the sink on hot while you take a shower. This kind of cancels out the savings on electricity.
Or get a higher flow shower head. Your screen on the shower head may be partially fouled.
Here is the brochure. It shows the flow rates for the different models.
http://www.stiebel-eltron-usa.com/sites/default/files/pdf/brochure-dhc.pdf
Dec 14, 2017 | Stiebel Eltron DHC 10-2 Electric Tankless...
Tankless water heater not meeting the need
Yes the faucet could be a problem. Try changing for one which you know is ok.
The long run of pipework - each bend, elbow or joint all have a reducing effect on the flow, maybe enough to matter with a restricted outlet. none of this can be altered except by renewing with larger bore pipe - expensive!
Also there should be a dirt filter in the mains water input line/pipe. Try removing & cleaning. Try also removing , reconnecting and then the hot tap [faucet]
The boiler will have an actuator valve which fires it up when a certain flow of water is reached. If the flow is reduced AND the valve is worn, maybe a replacement. Not sure about it's USA construction but in the UK [it's called a diverter valve] many have a rubber diaphragm which is cheap to replace
Check also if it uses a flow sensor switch
Had a look at the Takagi web site and there are pdf's of manuals
takagi.com
Overall I am still thinking that the main prob is in the flow.
Hope I've helped - come back anytime
Rod.Davies
Feb 19, 2010 | RTO Takagi Jr. TK-JR-N Tankless Water...
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Adjusting water flow
Apr 21, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Nov 28, 2008 | Water Heaters
Water Heaters Logo
55 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
