Question about Refrigerators
Testing defrost timer in gsl22jf
Freezer coils frozen, how do i check defrost timer and thermistat
catriver
  • 878 Answers
SOURCE: Fridge not working
Speed, If your model number begins with 596. This is made by Amana with the Kenmore name. Look at your defrost thermostat that sits on the evaporator, see if its bulged. If it is it's more than likley your problem. Part number 12001937. Your heaters should be calrod and seldom fail. Advance the refer into defrost by turing the mechanical timer clockwise until you hear it click and see if the heater comes on. Should find the timer under the control panel, should be a slot you can use a screw driver to turn it. If the heaters don't come on you can temp. by pass the bi-metal by simply cutting it out,connecting the wires and putting it into defrost again. However, it must be replaced. This is a safety device. If the heater now comes on, it's your bi-metal. If they don't come on with the bi-metal by passed, check for 120V at the heater connection. If no voltage, its your defrost timer. Careful in there your working with live voltage...Catriver post back.
Posted on Sep 07, 2006
  • 126 Answers
SOURCE: Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Posted on Dec 14, 2007
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
Posted on Dec 27, 2008
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
BIKER T
  • 909 Answers
SOURCE: Zanussi Zx99/5SI fridge not chilling freezer Frozen over
Tell you what, first do a good 12 hour defrost and restart. Chances are you left the door ajar accidentally. (even though you say you never,) Most of the time there is the issue. If it continues after that, let me know and ill go through the defrost procedure (the cheap way)..
Posted on Sep 26, 2009
Freezer coils are frozen up and the evaportation fan is working. Where is the defrost heater and what does it look like?
http://www.repairclinic.com/PartDetail/Defrost-Heater-Assembly/67001794/1022690 is what one looks like (since you didn't give your model number - couldn't look up the one you need)
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GTL21KBXABS/0432/0166000/G0904088/00002 It is item 58 on the diagram, but again not your exact schematic. The defrost heater is normally located very close to the coils.
But if you test your defrost heater and it is good (see video on first link on how to test) then you might have trouble with the thermistat - http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GTL21KBXABS/0432/0166000/G0904088/00002 or the timer - http://www.repairclinic.com/PartDetail/Defrost-Timer/482493/3348 and some whirlpools even have a defrost control board - http://www.repairclinic.com/PartDetail/Defrost-Control-Board/W10353224/1860724
Hope this helps!
Jun 10, 2011 | Whirlpool Refrigerators
The freezer drain hole freezes and then coil contunes to freeze until water forms on surface is defrost timer not working causing coil to freeze.
this is a defrost isue either defrost timer (or adc board) or bimetal defrost thermistat....very rarely the heater goes bad if it looks like a thick black coat hanger ....
Feb 03, 2011 | Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
My freezer is blowing but not cold enough to keep it frozen
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Test the compressor motor.
Hope this help in solving the problem. take care....
Sep 15, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
1965 Frigidaire unit - heavy ice build up on coils
Sound like the defrost thermistat or heater is bad. Regardless if you have ice block on coils defrost thermistat must be replaced. Even if still good it gets damaged. Empty out fridge and let manually defrost for 24 to 48 hours. With doors open and unplugged. Test heater with a meter to see if its still good. Replace defrost thermistat and plug back in.
Jul 10, 2010 | Frigidaire Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
I REPLACED THE DEFROST ASSY COMPONENT ON MY JENN-AIR REFRIG, BUT STILL WON'T COOL ENOUGH. fREEZER WON'T FREEZE side by side jcd2289
Make sure both fans are running and check that your the coil is not frozen. The coil is behind the freezer panel.
Jul 02, 2009 | Refrigerators
Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Apr 22, 2009 | Refrigerators
In addition to the popping noise/coils are froze with orignal
turns out the coils were not defrosting or at best working intermittently. I defrosted the coils and ordered a defrost timer the old timer continued to pop from intermittently.I replaced the defrost timer
and it quit popping and noew the freezer works fine temps range between 9 degrees F and
14 degrees f.
Jan 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My freezer is working but my Fridge is warm?
Sounds like a typical air flow (circulation) problem. This can be due to an evaporator fan not working, a frozen up coil not allowing air flow over it (due to failed defrost system, etc.) or even the damper for the fridge section stuck closed not allowing cold air from the freezer in. The first thing is to check the evap. fan to make sure it's running. It's easy to take the rear interior of the freezer section off and check for fan operation, solid ice on the coils, etc. If the coils have a nice white frost pattern all over then that's ok, but if they are frozen solid block where the air can't flow over them it's a defrost timer, defrost t-stat or defrost heat element (not likely) issue. Usually it's the t-stat or timer that goes out. The t-stat is easy to visually check to see if it's epoxy is "popped" out and of course a continuity check to be sure. The defrost timer is just a swap out sort of thing, not much to test there.
Jan 10, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
