Question about Dryers
Whirlpool Gold Ultimate Care II Gas Dryer takes to long to dry
We have had this dryer more than 10 years. About a month ago my clothes came out of the dryer smelling like smoke (though they were dry and there was no visible damage to dryer). We did a thorough cleaning of the vent system from the lint filter housing all the way through the inside of the machine (inside venting lines and vacuumed interior of unit; we even replaced the tubing out the back of the machine through the wall). Once we hooked back up the gas line and started using the dryer again it is taking a long time for the clothes to dry. Normally we could run a regular size load on the low setting to dry in an hour. Now it takes that same amount of clothing 140 minutes on the high setting to be dry. The dryer is heating, but it doesn't seem to stay hot the whole time. My thought is that something was damaged inside the dryer when the initial "smell" of smoke happened a month ago. We never saw anything inside that looked burnt (like from a fire), but obviously that smoke came from somewhere. What do you suggest we check? Any parts you think might need replacing? We are happy to DIY, but I'm not sure where to start. Thanks
    New Friend:
    Problem Solver:
  • 18 Answers
Sounds like ur t-stat is bad or maybe a thermal fuse. hard to say w-out diagnosing in hands on.
Posted on Jul 25, 2013
3 Suggested Answers
SOURCE: Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Posted on Feb 16, 2008
  • 686 Answers
SOURCE: Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Posted on Feb 18, 2009
My 10 year old electric dryer (Whirlpool Gold Ultimate Care II) is making a squealing, rattling noise. It still heats up, but something sounds loose. I wondering if I should get it fix or replace it.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 19, 2011 | LG DLG2524 Gas Dryer
My Whirlpool GOld Ultimate Care II electric dryer is not drying well any longer. It is 5 years old and a load must be run 2-3 times to get it to dry. Please help.
it could be your heating element but if you use dryer sheets take your lint trap out and see how well water will run thru it it may need to be washed in hot soapy water hope this helps
Dec 13, 2009 | LG DLG2524 Gas Dryer
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
I have a whirlpool gold ultimate care II electric dryer and have to dry everything on high twice to get it dried. any suggestions?
first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
May 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Mar 16, 2009 | Dryers
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
