Question about Farmall International Tractor 140 Radiator
H C International140
Point gap
Specifications for 1970 ford truck 360 v8 What is the timing, plug gap, dwell angle, point gap.
The plug gap should be .035
The timing 6 degrees btdc
dwell 24--29
point gap .017
Jun 20, 2017 | Ford Cars & Trucks
I have a 1993 ford Econovan maxi . I have ignition point . What is the gap on the ignition point . Thanks
point gap is .40 to .50 mm ( point 4 to point 5 mm) or .015 to .20"
most point distributors are at the .02 " mark but check and adjust as points to wide will misfire under load or lack power if too close
point gap variations can change ignition timing
Nov 20, 2016 | Ford Cars & Trucks
What is the dwell angle on a 3f engine if point gap is 18 thou
dwell angle is the no of degrees rotation between points closed and points open and for example on a 4 cylinder engine ( 4 lobes =90 degrees the dwell would be around 45 degrees available
there is an adverse relationship between point gap and dwell angle
the closer the points the bigger the dwell and conversely the bigger the gap the smaller the dwell angle
in a distributor the point gap of 18 would have a large dwell angle and that affects ignition timing
in your workshop manual there will be a dwell angle specification and if you set the points at .020 " that will put you close to the dwell angle specification
from there you adjust the gap to obtain the dwell setting
after yo have the dwell set , adjust the ignition timing
there is plenty of information on dwell angle, /point gap if you type in ---dwell angle to point gap relationship--
Aug 16, 2016 | Cars & Trucks
1968 Ford Ranchero
Spark Plug Gap is .032 inch. Many have started using .035 as it is easier to set using most newer tools.
Point Gap is .016 inch. You may also set point gap by using a dwell meter if you have one. That setting would be 32 degrees.
Aug 01, 2014 | Lisle 67870 Spark Plug Gauge Gap
Gape setting for points on massey fergson 135 gas motor ?
need spark plug gap and point gap for MF 135
I found this link about the points gap and plug gap.
"My I&T manual says .021 point gap and .025 plug gap."
There's a lot more information on the MF 135 on the web. Just do a search ' MF 135"; "massey ferguson 135 perkins gas engine point gap"
Jun 14, 2014 | Computers & Internet
Point gap 66 dodge 383
Considering its power and fuel economy, I'd go w the std plug gap is .035" to start & maybe experiment w .040". The std point gap is .016" & you might experiment w tightening that up a bit which will increase your dwell (more coil saturation time & a hotter spark) at the expense of shorter point life because they are closed longer & current is flowing thru them for a longer period of time but you are switching over soon. that might give you more gain than diff plug gaps.
Mar 30, 2013 | Cars & Trucks
Vw caddy rabbit 1.6 point gap spark plug gap?
Most point gaps are between .003 and .005 I would try a plug gap of 0.030 to start. I would be happy to give you exacts if you provide a year make and model.
Mar 18, 2013 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
What is the gap between he condenser and the piont
The point gap on all Briggs and Stratton engines is .020 inch
Mar 16, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
1981 converted to points, whats the point gap? and and the spark plug type and gap?
Point gap is about .018" if you can get the
timing aligned there. If not, vary the gap
slightly.
Spark plug is NGK BPR5ES-11 with a .022"-.025" gap.
Electronic ignition plug gap is much larger at .040"
Aug 20, 2009 | Harley Davidson FXDWG Dyna Wide Glide...
Farmall International Tractor 140 Radiator Logo
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
john milligan
Are you a Farmall Garden Expert? Answer questions, earn points and help others
