Question about Monte Carlo 5DI52WHD Discus White Ceiling Fan
Change light bulb
Not sure how to take the dome off to change to bulb could you please help thank you
    Genius:
  • Monte Carlo Master
  • 1,617 Answers
It twists off counterclockwise. If you have trouble try spraying a little WD-40 between the glass & metal frame.
Posted on Jul 26, 2013
How do you change the bulb on the deco dome touch lamp?
Looking at the picture supplied, it looks like you unscrew the top silver dome nut.
Please make sure it's unplugged when attempting.
Aug 07, 2014 | Universal Lighting and Decor Deco Dome...
Dome light bulb replace
There sometime is 2 fuse boxes on cars, one under the hood, and one inside the car somewhere. Check both boxes, make sure all the fuses are not blown, then if everything is good try replacing the switch in the door and/or on the dome light itself.
Dec 02, 2013 | 2000 Chevrolet Prizm
How do I replace dome light on Matrix 2009
Remove the key from the ignition. Make sure the doors are closed, so the new bulb does not illuminate when you are installing it.
Make sure the dome lighting switch is turned to the "Off" position. Pry the plastic lens away from the dome light. Use a small, flat-head screwdriver.
Push back the side bulb clamp. Pull out the old dome lightbulb. Wipe the area with a paper towel if it is dirty.
Wrap the new bulb in a paper towel. Insert it into the dome lightbulb holder. Push it up gently to secure it.
Turn the switch to "On" to test the bulb. Reposition the cover and push up to lock the clips into place.
May 28, 2013 | Cars & Trucks
I have a ford 6600 tractor not exactly sure of the year probably around 1977-1980. the 3 point lift arms wont lift worked fine then sat for a year when the clutch went out fixed that and now the lift arms...
How do I remove dome light
Not sure what type car you have but most dome light covers will just pop off with a small flat head screw Driver. Then take the bulb to your local auto pats store . They will help you with the right type bulb
Nov 07, 2012 | Cars & Trucks
Replacig a light bulb for a dome in 2001 dodgegrandcaravan
Remove the screw holding the dome light cover in place by turning it counterclockwise with a screwdriver....Remove the old bulb by twisting it slightly to the left and pulling it straight out. Dome light bulbs can be fragile, so be careful not to break the bulb with your fingers...Slip the replacement bulb back into place by pushing it in and twisting it slightly to the right...Replace the cover. I hope this helps, thank you for using FixYa!
Jul 02, 2011 | 2001 Dodge Grand Caravan
My dome light stopped working. I think the bulb may be burned out. How do I replace it?
the dome light cover just pops off by prying with a screwdriver..this will expose the bulb and you can probably figure it out from there... sometimes the bulbs unscrew out and sometimes they pop out also
Mar 25, 2011 | Chevrolet Malibu Cars & Trucks
I have a 2005 altima & my overhead interior light won't come on. I changed the bulb. The light came on for a split second and turned off. It never came back on.Can you help me?
sounds like the door sensor a plunger that recognizes when the door is open or if the connection going into the housing may be lose
Feb 18, 2011 | 2005 Volkswagen Jetta
Dome light in 97 mailibu doesnt work even with a new bulb
There shouold be a fuse in the fuse panel for this, or you may possibly have a faulty door switch that activates the dome light. Hope this helps
Jul 12, 2009 | 1998 Chevrolet Malibu
Monte Carlo 5DI52WHD Discus White Ceiling Fan Logo
146 people viewed this question
Top Monte Carlo Dryers Experts
ka4iup
ka4iup
Tom Chichester
Are you a Monte Carlo Dryer Expert? Answer questions, earn points and help others
