Question about Refrigerators
Samsung rs21dcns Heater in fridge broke so replaced it all seemed fine but water tank started leaking because it had frozen up. Have just changed this, now water dispenser won't stop the water coming out, pressure seems low too. Solenoid working fine ( checked without frigde tank connected ). Any ideas ?
    Sergeant:
  • 304 Answers
Did you thaw out the water tank and reinstall your filter
Posted on Jul 26, 2013
gwshaw71
  • 83 Answers
SOURCE: Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Posted on Feb 15, 2009
  • 7 Answers
SOURCE: Low flow from water dispenser
If there is a filter on the unit, change it. If not, then sounds like the screen is clogging up. You will need to pull the unit out and remove the water supply line and take off the adaptor to access the filter screen and clean it...
Posted on May 15, 2009
  • 396 Answers
SOURCE: Samsung RS21DCNS Water dispenser freezing up
Sounds like you have the freezer temperature set too low.
Posted on Oct 10, 2009
SOURCE: Samsung side-by-side fridge freezer model
HOW DO U CHANGE A WATER FILTER ON A SAMSUNG MODEL NO RS21DCSV
Posted on Feb 15, 2010
SOURCE: low water pressure on door dispenser
i have a similar problem. my water dispenser worked perfectly with the origional filter for about 8 month . then there was a decrease in water output. i then changed the filter.this worked fine for about 2 weeks . changed the filter again 2 days of water output. i have since changed the filter 2 more time with the same results. i do not have a kinked line . i have had the refer for about 1 1/2 years. ice production is down also . any thoughts?
Posted on Mar 10, 2010
What should I do about a small leak on the side of my water heater?
What is the warranty on this tank?
Warranties covered failed tank.
Does the tank wall have a leak?
If the tank is leaking on top around inlet pipes, or leak is coming out of weld around TP valve, then water heater must be replaced.
Copy following link for troubleshooting and method for prolonging life of water heater by turning off heater except to make batches of hot water.
http://waterheatertimer.org/Leaking-water-heater.html
You can buy water heater at local box store. $350 for gas and $230 for electric, then get store coupon or offer 10% less than sticker price.
Electric water heater is simple to replace.
Gas water heater takes more steps, but how-to step-by-step appears on following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 15, 2012 | Water Heaters
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
NO WATER COMING OUT OF WATER DISPENSER ON MY SAMSUNG RS21DCNS/XEU
you either have a kinked water line, or a frozen one. There is a possibility that the solenoid isn't working.
Nov 08, 2009 | Samsung Refrigerators
Oct 09, 2009 | Refrigerators
Samsung RS21DCNS Fridge not getting cold
0845 726 7864 samsung know of this problem and are doing free fixes to all of them just phone the number it doesnt matter about the warranty as they have extended them all free to 5 yrs.
There are numerous problems including noisy fan that stops when doors open to no water and all are free to fix.
Hope this helps.
Sep 01, 2009 | Samsung RS2556 Side by Side Refrigerator
Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Oct 04, 2008 | Refrigerators
I have a rs21dcns fridge freezer. i'm having trouble getting water from the water dispenser and also having trouble setting the temperature control for my fridge.
The water stops flowing from the dispenser when the external water filter needs changing, stick a new filter and it should start working again, it sometimes takes a few minutes to clear the air after the filter change.
Sep 07, 2008 | Samsung Refrigerators
Water not running on Samsung RS21DCNS - why?
Water tank in bottom of fridge can freeze up if thermostat gives up. First water will stop coming out, then ice starts building up, then fan starts making noise as it brushes against ice, then fan fails, then fridge warms up  ---- all a well know scenario with this fridge. I wonder if this is the problem you have ?
Apparently Samsung are now recognizing this as a design fault and extending unit guarantee. Ring them on: 0870 726 7864  and see what happens...
Jul 07, 2008 | Samsung Refrigerators
SAMSUNG RS21DCNS
The middle part of my refrigrator (RS21DCNS) is full of ice. i have removed ice many times. could you tell me whats the reason and solution of this?
Jan 15, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
