Question about Plumbing
Moen 7570 water pressure is low
5 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: my moen vestage faucet is dropping water pressure.
Have you removed aerator ,screen etc., from end of tap, to see how flow is with it off. If good, or same as other taps when taken off of them, then you've got debris in aerator, and screen.
Posted on Jan 03, 2010
SOURCE: I have a Moen single
I have had the cartridge replaced in my moen single handle faucet with sprayer in the end and now it turns off by itself. Any suggestions on the problem
Posted on Aug 19, 2010
  • 112 Answers
SOURCE: old moen vestiage kitchen faucet with current low
First check aerator at end of spout unscrew and clean or replace,if that dosen't work turn off water and take cartridge out of handle assembly and check for any foreign matter, clean out reinstall,take care to remember position cartridge came out.
Posted on Jun 12, 2011
  • 102366 Answers
SOURCE: moen plumbing product
Exactly what is "this" product?
Posted on Apr 28, 2013
Why low water pressure on MOEN Kitchen Faucet Model CA87316SRS?
sad to tell you this but all kitchen faucet mfg's have put in pressure reducers and as hard as I have tried personally I can not get good pressure at the kitchen either
Feb 14, 2015 | Moen Plumbing
I just replaced the O-rings on a moen faucet to stop a leak. The leak stopped but now there is low water pressure. The cold water was leaking but the pressure is low in both the cold and hot water. What...
possibly the aerator has trash in it. unscrew it from the end of the spout and flush it out. also could be the gaskets on the side of the cartridge bunched up when installed. remove and coat with non-petroleum grease (lowes has it) and re-install.
Dec 04, 2010 | Moen Home
I have a Moen single lever faucet. There is low water pressure coming from the faucet, Can anything inside the faucet be replaced to increase the water pressure? Thanks Bob Fruhling
Aug 15, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Turning on hot or cold water I get a loud screeching noise and very low pressure. If I keep turning the handle, I can get rid of the noise, but still low pressure.
It sound like you have sediment blocking your valve, faucet airiator or shower head (depending on what you're using). FYI: if it turns out to be defective all Moen faucets and showers have a life time warantee.
Jun 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
My moen shower faucet has low hot pressure and high cold pressure.
Either your water softener has a clog or your hot water tank has sediment build up in it.Either way your looking at have a licensed plumer come out and give you an evaluation.
Mar 20, 2010 | Moen & One Handle Tub & Shower Faucet
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
When shower valve is in middle setting pressure is low
No ,you are just lukewarm shareing 50/50 . if you need more pressure locate your homes pressure regulator usually just past 3/4 copperline as it enters house and before any water outlets. If this is Moen here too:
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 04, 2009 | Plumbing
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
