Question about HTC Touch Dual P5500 Smartphone
Touchscreen aint working
I wipe my touchscreen with a damp clothes and now the touch isnt working..if i reboot it will it work? model niki.
    Problem Solver:
  • 7 Answers
Replace his touch screen
Posted on Jul 25, 2013
Why does my touchpad on a acer aspire e11 keep freezing?
The touch pad might be faulty. Try to reboot the laptop after cleaning touch pad with a clean damp cloth. If nothing happens then the sensors under the touch pad could be faulty.
Sep 20, 2014 | Computers & Internet
Touchscreen isnt functioning
replace her touch screen and clean her parts
Jul 25, 2013 | HTC Touch Dual P5500 Smartphone
Sony VAio touchscreen hypersensitivity
Step 1:
Touch screen monitors are both input and output device as they receive and display information from one peripheral device the monitor screen without the use of mouse or keyboard. They are used in a variety of different applications such as point of sale (POS), cash registers, ATM machines, among others. Touch screen monitors are very sensitive so proper cleaning and maintenance is of utmost importance to maximize its performance and prolong its life. Follow these cleaning steps:
Turn off both the computer and touch screen. This way, you can see everything that needs to be cleaned. Some touch screen applications has a cleaning mode which turns off the screen for the specific purpose of cleaning. However, the monitor's brightness can make you miss some areas. Wet a soft, lint-free or microfiber cloth with distilled water. Wring out as much water as you can. Make sure the cloth is damp but not wet. Wipe the screen in a gentle motion to remove dust, oil, or fingerprint smudges off. Another option is to use a screen cleaner kit that includes antistatic wipes. You can buy this at various electronic or online stores. Spray a little solution on a wipe then rub it gently across the screen. Finish cleaning the touch screen with a dry lint-free cloth to wipe any excess moisture, then turn it back on.
Feb 23, 2013 | Sony VAIO Computers & Internet
Sprint zte fury touch screen unresponsive..any solutions?
Your touch screen didn't like "touching" your "really sweaty" chest! Te oils from perspiration are playing havoc with the screen. Use some rubbing oil on the screen with a soft cloth to remove the oils.
Jan 13, 2013 | ZTE Fury - 4gb - Black sprint Smartphone...
My wipe warmer isnt keeping the wipes warm any more only used it for 3 weeks and the lid is on tight
Make sure the "pillow" is quite damp (we put ours in dripping wet) and, if you're using cloth wipes, make sure they are damp enough before putting them in the warmer.
Feb 23, 2012 | Prince Lionheart Premium Wipe Warmer
Ink system failure error code: 0xc18a0306 what is the problem and the cure
Ink system failures can be caused by a number of things. It could be a temporary error, a bad or dirty print head, or a system failure.
For pictures see: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=en&cc=us&product=1156652#N998 . Expand the section "any other error code" if you need to.
First try resetting the printer. With the printer on, unplug the power cord from the printer then remove the other plug from the wall outlet. Wait at least 15 seconds. (I also pull the data cable from both the printer and the computer when using a USB cable - some power is provided through this cable.) Then plug the power cord into the wall outlet and then back into the computer. Turn the printer back on if needed. Check if the code is still present.
Next try cleaning the print head. With the power on, open the cartridge access door. Wait until the cartridge carrier stops moving. Remove all of the ink cartridges by pressing on the front tab and lifting them up. Then lift the grey handle and pull the print head straight up.
With bottled or distilled water and lint free clothes (coffee filters will work). Dampen a cloth and wipe the electrical contacts working form bottom to top. Do not touch the ink nozzles. Continue until there is no ink left on the contacts. With another damp cloth, wipe the edge between the nozzles and the electrical contacts working form left to right. (Keep your fingers away from the contacts.) With another damp cloth, wipe the ramps working away from the nozzles. Again continue wiping each area (using extra damp cloths until there is no ink left). Then dry each of these areas with a dry cloth. Take another damp cloth, and wipe the contacts inside the printer. Work from top to bottom on these contacts. Dry the area. Replace the print head, lower the gray lever, and reinstall the ink cartridges. Close the cartridge access door.
If the error persists, try resetting the printer by unplugging it while turned on again.
If the error still persists, either you need a new print head or the unit needs service. If you get a new print head, you will not be able to return it if that doesn't solve the problem.
I hope this helps.
Mar 22, 2011 | HP Photosmart D7160 InkJet Printer
I am getting ink error message Oxc19a0013
Is the phrase "Ink System Failure" in the message?
First check the cartridges. Remove all of the cartridges. Replace any that are low or empty. Check for damage or a blocked vent. Clear the blockage with a pin. If it is clogged with tape or the orange tab (that was in place during shipping), then remove the tape. Replace any that are damaged. Reinsert the cartridges and make sure that they are fully seated (clicked into place). Check if the error persists when you close the cartridge access door.
Try running the printhead cleaning utility from your computer. (HP Solutions Center under Setting, Print Settings, Printer Toolbox and follow the on-screen directions).
Remove the printhead and clean it. Then reinsert it and make sure it is fully seated. Remove the cartridges, lift the latch handle on the right and lift the print head straight up. This is done with cotton swabs or lint free clothes (coffee filters will work) and distilled or bottled water. During the cleaning do not touch the nozzles; also do not touch the contacts with your fingers. Wet the swab or cloth and wring out the excess water. Wipe the contacts on the printhead with the damp cloth first by wiping up towards the nozzles. Then with another damp cloth wipe the edge between the contacts and the nozzles (work in a right to left motion). Finally wipe down the ramps going away from the nozzles with another cloth. (Wipe each part until there is no ink left.) Dry each area with a fresh cloth.
Next take another damp cloth and wipe the contacts inside the printer. (work from top to bottom.) Dry the area.
Reinstall the printhead and lower the latch handle. Then reinsert the ink cartridges until they snap in. Close the cartridge access cover and check for the error message.
If the error persists, reset the printer. With the printer on, disconnect the power cord from the back of the printer. Disconnect the other end of the cord from the wall outlet. Wait at least 15 seconds and then plug in the cord (first to the wall outlet and then the printer). Turn on the unit.
If the error persists, then either the printhead needs to be replaced or the unit needs service. Unfortunately a new printhead is not returnable if you put it in and find the error persists.
For details and pictures: see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3737195#N65 .
I hope this helps.
Dec 12, 2010 | HP Photosmart Premium C309A All-In-One...
Cant use my touchscreen
Hi there
First remove the protective cover (if any) the protective cover may be preventing the touch screen from working properly
Oil or residue from your hands can build up on the screen and interfere with the touch screen function.You should clean the screen with.
To do this, turn off your phone and disconnect any cables. Put a small amount of water on the corner a soft microfiber cloth, like those used to polish musical instruments.
Gently wipe the phone with the damp cloth until it is clean. Dry and lightly polish the screen with the dry end of the cloth. The towel should be damp,
. When the Phone is completely dry, put it back in its case and power it on. Do not put water directly on your Phone
If all these still do not make the touch screen work then you should have your screen replaced.
Oct 02, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
TOUCH SCREEN DOES NOT RESPOND
Try cleaning the face carefully with a damp cloth with a bit of Dawn dish soap and re-wipe with a damp cloth with no soap. Sometimes dirt or small tranfers form your fingers can lock up the display grid.
Feb 10, 2010 | Tomtom GO 720 GPS Receiver
Cleaning touchscreen without damaging it.
Proper cleaning of a Touchscreen
  1. Step 1 Turn off both the computer and touch screen. This way, you can see everything that needs to be cleaned. Some touch screen applications has a cleaning mode which turns off the screen for the specific purpose of cleaning. However, the monitor's brightness can make you miss some areas.
  2. Step 2 Wet a soft, lint-free or microfiber cloth with distilled water. Wring out as much water as you can. Make sure the cloth is damp but not wet. Wipe the screen in a gentle motion to remove dust, oil, or fingerprint smudges off.
  3. Step 3 Another option is to use a screen cleaner kit that includes antistatic wipes. You can buy this at various electronic or online stores. Spray a little solution on a wipe then rub it gently across the screen.
  4. Step 4 Finish cleaning the touch screen with a dry lint-free cloth to wipe any excess moisture, then turn it back on.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 03, 2010 | HP Pavilion TX2000Z Notebook
HTC Touch Dual P5500 Smartphone Logo
54 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
