Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
Diagnostic test 66517829000 - Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
I have a 04 explorer and I put anew fuel pump an my gauge on the gas hand still don't work but number 17 fuse is hot on both sides what is 17
Where ? under hood fuse box or inside fuse box ?
F1.17 20 Four-wheel drive control module (14B466)
F2.17 15 Battery saver relay, Accessory delay relay
Visual Inspection Chart Mechanical Electrical
  • Engine oil level
  • Door adjustment
  • Engine coolant level
  • Fuel tank
  • Fuel evaporative system
  • Battery junction box (BJB) fuse 15 (5A)
  • Central junction box (CJB) fuses:
    • 15 (5A)
    • 21 (5A)
  • Miniature bulb(s)
  • Circuitry
  • Instrument cluster
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the concern is not visually evident, connect the diagnostic tool to the data link connector and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card or disk is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • SCP or UBP circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for the instrument cluster, Go To Pinpoint Test G . For vehicle security module, refer to Section 418-00 ; for anti-lock brake system (ABS), refer to Section 206-09 ; for restraint control module, refer to Section 501-20B .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and carry out self-test diagnostics for the instrument cluster.
  1. If the DTCs retrieved are related to the concern, go to the Instrument Cluster Diagnostic Trouble Code (DTC) Index or the Powertrain Control Module (PCM) Diagnostic Trouble Code (DTC) Index to continue diagnostics. For all other DTCs, refer to Section 418-00 .
  1. If no DTCs related to the concern are retrieved, GO to Symptom Chart to continue diagnostics.
Instrument Cluster Self-Diagnostic Mode
To enter the instrument cluster self diagnostic mode with the engine off, press and hold the odometer reset button (base cluster) or the message center reset button (message center cluster). Turn the key to the RUN position and hold until the display indicates tESt (base cluster) or TEST (message center cluster) usually within three to five seconds. Depress the reset button once to advance through each stage of the self-test.
To exit the instrument cluster self-test mode, turn the ignition to the OFF position. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
  • Incorrect fuel gauge indication
  • Circuitry.
  • Fuel level sensor.
  • Fuel pump module.
  • Fuel tank.
  • Instrument cluster.
  • Go To Pinpoint Test H .
You need to test , don't guess ! Your best bet would be to take your vehicle to a qualified repair shop .
B1201 Fuel Sender Circuit Failure Instrument Cluster Go To Pinpoint Test H . B1204 Fuel Sender Circuit Short to Ground Instrument Cluster Go To Pinpoint Test H .
Jun 07, 2016 | 2004 Ford Explorer
Tip
Self Diagnostic test
Having troubles with your Axim x51V?
You can allow the device to perform a self diagnostic test that will make it run a series of tests (CPU test, LCD test, RAM test, Interactive Button test, Sound and Recording test, Touch Panel test)
To enter the diagnostic area, Press and hold POWER and RECORD while pressing the reset button on the back. Continue to hold the POWER and RECORD buttons while releasing the reset button and wait for the screen to show the diagnostic window. Select the envelope icon button to begin the test or press calendar icon to exit and reboot without testing.
on Mar 14, 2008 | Dell Axim X51v Pocket PC
Diagnostic error 2000
Moultrie liebherr diagnostic Digital Cameras Questions ...
www.fixya.com > Forum > Tags > liebherr diagnostic > Digital Cameras
Moultrie digital cameras liebherr diagnostic related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
moultrie diagnostic test error 000480 Digital Cameras ...
www.fixya.com > Forum > Tags > moultrie diagnostic test error 000480
Digital Cameras moultrie diagnostic test error 000480 questions and answers. Ask your moultrie ... ...moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
Moultrie diagnostic code 12 Digital Cameras Questions ...
www.fixya.com > Forum > Tags > diagnostic code 12 > Digital Cameras
Moultrie digital cameras diagnostic code 12 related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
Jan 20, 2016 | Cameras
How do I run diagnostic test
Washing Machine Diagnostic Test & Error Codes (Cabrio ...
? 1:29
https://www.youtube.com/watch?v=yoCTzbl4FPs
Nov 22, 2010 - Uploaded by applianceassistant
Washing Machine Diagnostic Test & Error Codes (Cabrio, Bravo, ..... What can i do? ... I tried to put it in ...
Fix and Diagnose Kenmore Oasis / Whirlpool Duet hE Washer
? 7:21
https://www.youtube.com/watch?v=8Z1JdsJYa14
Apr 24, 2011 - Uploaded by Alprazolam
Tried to do the diagnostic test and it still won't do anything. ... If the latter, and it won't run any diagnostics ...
How do you do a diagnostic test for a Whirlpool Cab
Dec 02, 2015 | Washing Machines
Spot screen
Hello
First find an external monitor to test if its the screen on your laptop or the graphics chip in your laptop. If you have an external monitor then hook it up to your laptop and toggle the video over to see if you still see the spot.If it only shows on the laptop screen the Replace the screen.
Another thing you can do is run the built in Diagnostics
Diagnostics before windows using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen.
Dec 18, 2013 | Dell Vostro Computers & Internet
Internal hdd hard error
Using the F12 Diagnostics
Nov 19, 2013 | Dell Latitude D610 Laptop Computer -...
Helo i try to play a game and i get nmi memorry parity error blah blah, with a blue screen.
There are number of things that can cause an error like this. Faulty memory, a bad harddrive, a failing motherboard, or a corrupt OS.
If you get this error every time you power on your PC than follow the below steps
It probably meant the installation itself was corrupt, not the disk you were using.
To test your memory try Windows Memory Diagnostic Test
http://oca.microsoft.com/en/windiag.asp
The Windows Memory Diagnostic tests the Random Access Memory (RAM) on your computer for errors. The diagnostic includes a comprehensive set of memory tests. If you are experiencing problems while running Windows, you can use the diagnostic to determine whether the problems are caused by failing hardware, such as RAM or the memory system of your motherboard. Windows Memory Diagnostic is designed to be easy and fast. On most configurations, you can download the diagnostic, read the documentation, run the test and complete the first test pass in less than 30 minutes.
Or you can try memtest
To test your hard drive for corrupt/bad sectors find the manufacturer of your hard drive and run their Hard Drive Diagnostics Utility.
This will give us a foundation to work on and will (should) eliminate two possible sources of your problem.
Jan 06, 2011 | Lenovo ThinkPad T61 Notebook
When I try to run printer test dvd writer test dvd rom Drive test etc I receive the following message - Exception in display runmap.runmap:
What diagnostics software are you using for the tests? hp?
It is posssble the diagnostics software package is the problem.
Try another diagnostics software and test if it produce the same errors!!
Jul 05, 2010 | Computers & Internet
No heat coming out fan blows but no heat
there's a blend door actuator behind the dash. they are going bad all the times. however, check your coolant level first.
Feb 28, 2010 | 1996 Lincoln Town Car
Paxar 636 diagnostic test 2 error
paxar 636 diagnostic test 2. i've encounter this problem last 2004. the diagnostic test stops at diagnostic 2. what we did is that we've checked the mother board and the printhead board. basically those boards are the main problem when you encounter that error (diagnostic test 2 error ). what we did is that we changed the mother board as well as the printhead board.
Aug 02, 2008 | Avery DesignPro Deluxe CD-ROM...
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
27 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
