Eps 1501-x Seems to be struggling to shred just one page these days. I tried to clean the shredding blades but that did not make any difference.
  • 221 Answers
Oil them blades. Try using any type of active spray oil, the run in reverse for 2-3 minutes and try again. Should be good as new
Posted on Nov 03, 2013
SOURCE: My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
fellowesrep
  • 102 Answers
SOURCE: shredded paper is wrapped around blades
Try saturating paper jam with liquid vegetable based cooking oil from your kitchen this should soften the paper after sitting 6-7 hours
Posted on Feb 23, 2008
SOURCE: Won't shut off after shredding.
I FIXED MINE!!! Hey folks same problem AS1018CD would not shut off. CURE: Take apart and clean electronic eye. PROCEDURE: 1. Unplug. 2.  Remove shredder and turn upside down. 3. Remove 6 phillips head screws on back of unit ( 1 is under sticker in middle peel back sticker to access screw. 4. Carefully separate unit. 5. Pull off shredder piece. It is a snug rubber grommet fit and just lifts off( gears everything comes off as one piece. 6. Electric Eye is exposed remove screw holding in and gently slide out and wipe clean. Do both sides. While apart clear all debris and wipe entire unit as clean as you can. Put gear assembly back on grommets. Put top and bottom back together. Replace screws. Plug in. FIXED :-)
Posted on Jul 11, 2008
geemarie
  • 876 Answers
SOURCE: SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Posted on Aug 01, 2008
SOURCE: Shreds halfway, then stops. Fellowes SB-95C
on the underside of the shredder, at the top of the space where the cuttings box is, there are 2 sensors, 1 at either end of the shredder blades. it sounds like these sensors could be either dirty, or defective. try to clean these with a cotton bud or similar. it may need new sensors, bu it is worth a try!
Posted on Feb 05, 2009
I can only shred 6 pieces of a paper then I have to let it cool down for 30 min. It is literally an all day process to shred 30-40 pieces of paper!!!#
the cost to repair ( if parts are available) generally are more than a replacement unit
it is possible that the shredder blades are blunt or damaged from staples and it is not cutting the paper but tending to tear it and that makes the motor work hard and over heat
Mar 21, 2016 | Office Equipment & Supplies
Omnitech wont shred papers.
Sounds like its jammed? Have a really close look for staples, paperclips etc stuck in the drive gears or blades
May 19, 2015 | Office Equipment & Supplies
My Staples 16 sheet Microcut shredder starts the shredding operation after I push the button and continues the shredding operation after I shred a paper. How can I get the shredding mechanism to stop...
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
Mar 14, 2015 | Staples Office Equipment & Supplies
CAN THE BLADES ON A FELLOWES 99Ci SHREDDER BE SHARPENED?
I do not believe so. Never heard of sharpening one. The shredding blade is pretty complicated. The manufacturer has a good support web page I suggest contacting them. Keep it clean and oiled and it should last a long time. And do not shred stuff listed on the cannot shred list.
Feb 06, 2015 | Fellowes SB-99Ci Shredder
Odd metal to metal sound
You can't really clean the blades...however , a x-cut shredder should be lubricated regularly....try putting some shredder oil on a sheet of paper and shredding it...do this a number of times to get the oil down into the cutting blades, see if that helps.
Apr 09, 2010 | Royal VF1000MX Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Jul 21, 2009 | Royal Office Equipment & Supplies
SPL 1506X Shredder
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
46 people viewed this question
jasbo
jasbo
