Question about Garden
Flymo met 250-4 trimmer
I have just acquired the above tool but have no instructions, how do I turn it from lawn edge trimmer to lawn strummer? Product No. 9648518-25 if that helps
3 Suggested Answers
  • 246 Answers
SOURCE: no user manual
Hello:
Most 2 Cycle Engines use a 32:1 or 40:1 Fuel Mix Ratio.
The Newer 2 Cycle Engines use a 40:1 or 50:1 Fuel Ratio.
For Better Performance and to be sure you have Plenty of Oil to the Engines Internal Components, I Suggest (and I Use) a 32:1 Ratio in All my Equipment except for Post Hole Diggers.
Post Hole Diggers Use a 25:1 Fuel Ratio.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
mark24354
  • 776 Answers
SOURCE: How do we operate the trimmer to change it to trim
Most string trimmers can do this. Just turn it half-way around so the black handle is close to the ground (now string will spin in a verticle sweep instead of parallel to ground). Just walk along sidewalk nad trim. You will have to hold tightly to keep the line straight (brace against your hip and try to make several passes and cut a little at a time).
You may have a button that allows you to only turn the cutting head half way around (so you don't have to use your thumb to operate the switch). Either way, it will work fine.
-Mark
Posted on May 05, 2011
My Flymo Contour 700 stopped working when in use how do I get it to work again
check its safe to keep using
an electrician or flymo service center to check it all over
Sep 11, 2016 | Garden
How do i start the mccullough mt 270 grass strummer
You have to start at the beginning. Do you have spark and fuel?
Sep 16, 2014 | Garden
Flymo trimmer 700 wont switch on
if you can disconnect the switch wires and it starts you will have to choke to stop machine . but you will know if switch is faulty , sometimes it just dust in the switch itself , try blowing switch with compressed air first .
Mar 11, 2014 | Garden
How to put line on spool of flymo 700 series
There is a very nice and easy to follow diagram in the manual. Here is the link for the Flymo Power Trimmer 700 Series Manual. I hope this helps you out!
Jan 07, 2013 | Electric Garden
When my flymo lite 250 engine is running the end does not turn to cut the grass
Could be anything from a stripped drive shaft to a loose or stripped trimmer head. You'll probably need to take it to a repair shop to have them diagnose the problem and locate the replacement parts if it's anything other than a stripped trimmer head bolt.
Nov 01, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a flymo ct250 strimmer. when charged the
could be battery or just needs grease inside the shaft
Sep 19, 2009 | Garden
Replace line in poulan electric weedeater model xt110 twist'n plu
Dear FixYa Fan, Friday 2-20-2009 10:44pm EST (USA)
RE: Poulan Lawn Trimmers
Poulan Lawn Trimmer FAQ @
http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html
Dear fitzknight: You will find instructions for putting line on your trimmer at this link http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html#changeline click on the http line preceding but please rate me 1st or come back and rate me before you close this or the Poulan Site!
Thank You,
jackiaria
Feb 21, 2009 | Poulan 12" Electric Twist N Edge Plus...
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
