Question about Intel D946GZIS Motherboard
Black screen no beep - Intel D946GZIS Motherboard
  • 17 more comments
  • Federico Jul 25, 2013
    Double post. Please delete it.
    Double post, please delete it.
    seems I have some issues using fixya via android...
    No, there are no issues with cable or monitor, I connected trough VGA and HDMI, I have tested the system with an external video card pci-e too. I've reset the bios and tested the motherboard just with the cpu, then I tested with a single dimm of ram at time. I didn't change anything on my configuration. The psu was tested too. Simply the system is apparently dead but fans spins just fine.
  • Lars Olsson
    Lars Olsson Jul 25, 2013
    remove external videocard.use the intergrated grafics.and clear CMOS.
    Already tested. Look my previous comment. This machine NORMALLY operate without an external video card.... The unique jumper I found for BIOS let me set it in configure mode or in recovery with the same result.
  • Lars Olsson
    Federico,what was that first symptom was it the black screen.?
    No one, it's an old winxp machine. I turn it off normally and now it's apparently dead.
  • Lars Olsson
    what was your first problem intel D946GZIS motherboard.
    First problem for what I know: was a computer of an old woman, barely used. For sure she never did a bios update or any kind of upgrade. Worked just fine for two weeks.
  • Lars Olsson
    did this happend after a BIOS uppdate.? clear CMOS by lift out cmos-battery about 20 sec. watch out for the hooks.
    LArs, don't want to be rude but seems you aren't reaing what I write: no update or upgrade were made on this machine. Simply stopped working. Remove the battery for more than 5 hours did not reset CMOS.
  • Lars Olsson
    federico,no were did you metion you lift out cmos-battery.let's leave tha now a question HOW OLD IS the COMPUTER.
    Dude, I did just commented the fact you didn't read what I wrote about "update and upgrade" because you asked about a bios upgrade. The part of my reply about the battery comes after the end of the phrase. :)I don't know the story of this pc before I grab it but the motherboard is dated 2007. I tried now whit a P4 3ghz to see if was a problem with cpu but it's the same. Is simply dead, case closed. Thanks for the help anyway.
  • Lars Olsson
    DID YOU REALLY WONT HELP DUDE ???
    Please could you gently write without CAPS enabled? I just clarified what I wrote. Now, I simply realized you (or others) can't help, the computer is just dead and it's ready to the trashcan. :)
  • Lars Olsson
    Federico,try with a other PSU if possible.psu are often a cause of malfunction
    I know but I checked the PSU using a multimeter and the output was quite good. But this weekend I can try with another PSU need just the time to pull out from another PC. :P
  • Lars Olsson
    why you should try with a other psu i read on internet multimeter are not totaly reliable.
    Brigadier General:
  • Intel Master
  • 3,400 Answers
TRY WITH A OTHER MONITOR MAKE SURE THE CABELS ARE SEATED TIGHT AND FIRMLY.
Posted on Jul 25, 2013
3 beeps and black screen
it is likely a motherboard issue and your computer might need repairs
Jan 07, 2014 | Dell XPS 730X Desktop Computer
Beeps ram, blue screen, black screen
http://www.computerhope.com/beep.htm
READ THIS FOR SAME HELP.
IT IS PROBERLY THE RAM AND VIDEOCARD NEEDS ADJUSTMENT.
Dec 16, 2013 | HP Pavilion s7600n PC Desktop
Hi. I Inherited a DELL Poweredge 1600SC server. When I switch it on, it powers up but the screen remains blank [black without any beeps]?? I remove all the memory and switched it back on again = NO beeps....
I guess you can't go into start button. /anyway how did you know if computing is powered? On your keyboard top line keys have screen control keys for brightness etc.eg f4. try.
Aug 01, 2013 | Dell PowerEdge 1600SC Server
Everytime i boot my pc,it beeps 2x,then black screen,so i have to reboot again
The beeping is caused by your computers POST( Power On Self Test - learn something new everyday! ;) )
Find your motherboard manual, and have a look in it for beep codes, or error codes. The number of beeps will let you know what kind of problem you're dealing with.
If all is well in POST, your computer should only beep once, and continue.
Can you get into BIOS at all, or does it just show you your videocard info on bootup, then black screen?
May 27, 2011 | Microsoft Windows XP Professional
My pc boots, the the screen is completely black.
If you can see the bios screen at the boot . After that your screen is black.
The OS might be corrupted I suggest you to reinstall the OS by using the re-installation Disc.
If you are getting any beep sound then the error codes of one long beep & 2 short beep Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
If you don't see the bios screen & beeps, there might be problem with the screen or the VGA chip in the motherboard.
If so I suggest you to contact the service center near by.
I am sure this will be helpful for you.
Rate my solution
Regards
May 31, 2010 | Gateway ML3706 Notebook
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
Black screen
hello, those beeps you hear usually means some error, and it depends on how many beeps you hear and in which sequence. below you will find several BIOS vendors and their beep codes which help you detect the problem:
http://www.chem.pitt.edu/facilities/bios_beep_codes_list_v3.pdf
hope this help let me know if you need further assistance.
good luck,
regards,
Amar Sondhi
Dec 07, 2009 | Toshiba Satellite P25-S5263 Notebook
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
Black screen when i turn on the computer
post comment in my yahoomail so thAT i can kep in touch with you!!sergio_bonjovi@yahoo.com
when you turn on the computer does the computer beeps?how many times does it beeps? when your computer beeps 3 times faster..try to check you video card!!!! but when the computer continues to beep and beep try to check the modules or the memory try to replace it with a new memory!!! but when you turn on your pc and no beep at all your motherboard will be the problem?so did i answer your questions?
Apr 25, 2009 | Compaq Presario 5000 PC Desktop
Intel D946GZIS Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
