Question about Koutech Systems PC720 (IO-PC720) (IOPC720) Serial Adapter
Canon copier pc 720
Coppier loads paper half way after the paper stops the machine still works for another minute, the scanner portion does not move during all tnis time and the the machine operating noise stops and an error code of E220 shows up. can you please tell me what this error code means.
Chnge toner cartridge
Posted on Aug 30, 2007
Error indication E2 20 means it's too cold in the room where the copier is located. - from operators manual
Posted on Nov 28, 2007
Canon copier PC 720 was shut off halfway through travel and now will do nothing
You probably have a sheet of paper part way through the paper feed path. Locate and remove it. If it comes out in pieces - put ALL the pieces together to ensure it has all been recovered. Power the machine off and wait 30 seconds before powering on. Hopefully that will sort it for you.
Dec 27, 2014 | Canon Office Equipment & Supplies
Canon mg2120 will not print online
I just installed a canon mg 2120 printer to a new toshiba pc with windows 8. canon box and retailer It shows it's compatible. Went through all installation process, but printer keeps saying that it's "out of paper". I've loaded and reloaded the tray a dozen times. Printer just won't catch paper and run through the machine. What's wrong???
Dec 31, 2012 | Canon PIXMA MG2120 - multifunction ...
Bottom half portion of the paper horizontally gets black (dark)
I would presume that somwheare beneath adf is light coming to scanner. Try to adjust height and possition of adf on adf hinges.You have two screws, one for height, and other for left or right possition.
May 25, 2010 | Canon imageRUNNER 5000 Copier
Canon MP560 brand new. Don't have booklet available. How do I load the paper from the back? Thank you!
reach behind where scanner hinges on back of printer in middle and gently pull up. Once it's completely pulled up -- about 6 inches, you can let it fall back away from the printer and the top portion folds out. You can feed paper in from the back that way.
Feb 23, 2010 | Canon Office Equipment & Supplies
Canon PIXMA MP240 scanner problems (physicl, not digital)
when i load paper it feed cockeyed,,,when rollers start it appears to only fee on one side and crinkles paper ..turns sideways and stops feeding....Help !
Nov 24, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Shows paper Jam on Canon 720 PC photo copier
Sounds funny but this model shows a jam when the exposure lite goes bad. Turn on the copier and watch the exposure lamp, should lite up and not flicker. Lamp is still available.
Nov 16, 2009 | Office Equipment & Supplies
Canon Mx300 wont recognize my paper. says:load paper
I cant print...orange light under alarm keeps flashing...please help...patricia
Jun 04, 2009 | Canon MX300 Office All-In-One Printer
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Canon PC-D320 prints only left half o document with closed cover
I had the same problem but it was caused by the scanner that was not running flash under the copier glass,if I remember correctly there are spacers on the scanner that keep the scanner to run exactly the same distance from the glass of both sides of the scanner.
On the other machine,I found a faulty scanner cable that cause a similar problem.
Jan 30, 2009 | Canon PC-D320 Copier
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
Koutech Systems PC720 (IO-PC720) (IOPC720) Serial Adapter Logo
677 people viewed this question
Top Koutech Systems Computers & Internet Experts
David Payne
David Payne
Are you a Koutech Systems Computer and Internet Expert? Answer questions, earn points and help others
