Ford 4630 tractor
Best way removing starter motor
  • 8404 Answers
SOURCE: my 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Posted on Nov 09, 2009
SOURCE: How do I remove the starter on a Ford 8N tractor?
Funny you should ask. I just got in from doing just that.
1: Disconnect the battery
2: remove the seloniod (I just unbolted and unscrewed it from the starter and left the wires on it so I wasn't trying to guess what went where later when I get back to reassembling it.)
3: you have 2 bolts at the rear of the starter (the part of the starter that faces the front of the tractor.) You unscrew them to take the starter out. BE CAREFUL - if you pull the starter apart it will be a bear to get the brushes back in.
I had the additional problem of the "bendix" (the part that engages the flywheel) jumping over the flywheel so I needed to remove the bolts on the canister to the left of the starter and move it slightly out of place in order to complete the project. You may not have to do that but I mention it as a aid because I don't know why you're changing out starters.
In my case I found that although the starter was spinning the shaft was being chewed up because the engager (bendex - whatever its called) had jumped the flywheel and was resting against the flywheel. Really needed extra space to pull the starter because of that.
Also saw somewhere that that bendix needs to be drawn in in order to reinsert the starter (something about having to spin it in??? I'll be looking for that shortly myself.
Posted on Jan 16, 2010
  • 203 Answers
SOURCE: Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
mytractorforum.com
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
Posted on Nov 27, 2011
  • 6468 Answers
SOURCE: starter motor spins won't engage flywheel on lawn tractor
take it off and see if the gear is broken (you can buy the gear at napa)or did the shaft the gear rides on got a little rusty over the winter
Posted on May 12, 2012
  • 129 Answers
SOURCE: do i have to remove oil pan on ford 8n tractor to remove motor
No it should come out with it on. There is nothing to unhook on the oil pan so it will stay inplace when you take the motor out.
Posted on Nov 26, 2012
Ford 4630 tractor fuel system manual
Your might be able to obtain a new manual at Helm Publishing in Highland Park, Michigan. Try a Web search for this info also. A really really good Tractor Dealer in farm country might want a Farmer to stay "Ford Loyal" by supplying this info and keeping a potential new equipment customer.
Nov 16, 2017 | Ford Cars & Trucks
How do i find a starter wiring diagram for ford 4630 tractor
Try this web link: http://www.maidaozhi.com/ford/ford-4630-tractor-wiring-diagram
Oct 18, 2016 | Ford Garden
Do you have a wiring schematic for the starting system on a 1994 Ford 4630 Diesel Tractor?
Randy, Check the attached link and scroll through it, hope it has the info. you need.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1994 Ford 4630 Diesel Tractor wiring schematic for the starting system...
Apr 22, 2016 | Ford Cars & Trucks
How to remove starter on 06 ford taurus
I usually use a starter removal tool... you want the correct answer, engine size and posting this is the automotive section will help
Aug 23, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
Starter removal 9n tractor
Hope you have remove now. Remove the 2 mounting bolts. Then,
dip starter down and inward to clear the flywheel.
Dec 16, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
New starter motor and bendix. will not engage with flyweel. starter motor just spins.
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
Nov 08, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
How to remove starter drive on ford 9N
You need to compress the front of the drive enough to drive out the roll pin,then the drive should slide right off.
May 06, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
Replacing 8N starter motor
IT helps to loosen the oil canister ahead of the starter and then begin inserting the starter with it tipped upwards and then gradally lift it as you insert it.
The hole should be oblonged out to make for easier insertion of the starter shart..
good luck.
Marc
Aug 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
15 people viewed this question
 Grubhead
Grubhead
