Question about Quinny Baby Gear
Helpline Handle bar broke on connector
  • Quinny Master
  • 1,629 Answers
Hi Mary
Which model Quinny do you have and which country are you in?
Posted on Jul 27, 2013
Beater bar stays engaged when handle of dyson animal 17 is in the up position
Hi Richard,
I'm sorry to hear you're having difficulty with your DC17. The issue you've reported sounds very unusual, and we'd appreciate the opportunity to provide further assistance. Please give our customer Helpline a call on 1-866-693-9766 - alternatively, if you email us at askdysonUS@dyson.com , someone will be in touch as soon as possible to discuss this with you.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 20, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Outside door handle won't open door
replace bar linking inside with outside handle undo handle remove square bar inspect both parts replace which ever is worn or broke
Apr 06, 2012 | 1990 Jaguar XJ6
Fix broken rear hatch handle
will need to remove the rear panel to access the latch mechanism the release bar connector either popped off or broke the clip is only a few bucks and is easily replaced the hassle is in the removing of the panel
Nov 19, 2011 | 1999 Ford Explorer
How to remove door handle on 99 oldsmobile aurora
unscrew the 2 screws on the bottom of the inside panel, then unscrew the large phillips head right behind the interior handle and remove the plastic cover next, you need something stiff and wide and flat, like a large meal file with a t-shirt wrapped around it so it doesnt **** up the leather pry it UP and a little bit outward and it will pop off, I was going on the fly and broke the little brackets and I had to us 1minute gasket to seal them back on really well. the connectors come off by the little clips on the side, stick a flathead along he side of the connectors and they will click out, you will feel them slip loose. not the panel should come free from the coor. next you need to remove the flat metal cover that has 2 bolts in it, basically right in the middle with the right side bolt touching the lock mechanism as well. it will unbolt then slide the tabs down and out...easy. the door handle is held on by 2 bolts, youll have to squeeze your hands to the right of the metal slider for the window and over the metal bars for the lock. I got the left one with a wrench and the right one I had to stick my left hand where I mentioned and m right hand had the wrench. the handle will be free by then, and you can slide the left side out first. then gently pull the bottom of the handle housing out and to the left at the same time and it will pop out. un-screw the two bolts to remove the bars from the lock on the bottom and the top elbow comes off as one piece with the metal bar going downward.
and there you go buddy...I just had to fix my door handle and it reuied removing it, just did it today. took about 2 hours, but I had no idea what was doing and had to figure out the mechanism by myself...computer broke conveniently enough!
Jan 27, 2011 | 1999 Oldsmobile Aurora
Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Back hatch handle broke off! How do I get the
call dealer they wil know best way to deal somtimes we drill the bolts out of handle to remove and pull up on handle to open hach
if there is still a hinge piece there usa a screw driver in hinge poing to rotate bar assembly
Jan 15, 2010 | 2005 Scion xB
Hinari cafe continental Mod. EC2 replacement glass coffee holder.
Have you tried the helpline number in the instruction manual? 02087 873111
Mar 17, 2009 | Coffee Makers & Espresso Machines
Replace handle bars
Mine had wiring inside the bars as well. Basically I removed the controls from the bars, and removed the 2 bolts holding the handle bars on. I removed the RIGHT side gas tank after draining it. I intended on cutting the wires to the connectors, pulling the wires out of the old handle bars, and pulling them back through the new bars. Note: Mark the black wires very carefully, since there were 5 black wires in the two connectors and they are all unique wires. The colored wires were easy, just match them back up. Several tricks I found on line. Use a string and a bolt to fish a pull line down through the new bars then pull the wire bundle through. This worked great on both left and right wire bundles. I then bolted the new handle bars in place and remounted the controls. I then replaced the shrink tubing up the bundles that hid the actual wires as they came out of the handle bars down to where I cut the connector wires, behind the right side tank. Next I stripped and tinned all the wires I cut (twist and get a little solder to stick on the wires) and stuck little pieces of shrink tubing up or down the wire so after I resoldered the wire I could shrink the insulation back over the splice. I picked up the shrink tubing and some extra wire a home depot. I had a soldering iron, and heat gun so away I went connecting the dots again. Litte tedious but hey. It saved me somewhere between $500 -$700 bucks which is what the harley shop quoted before I started. I tested each function, then reinstalled the gas tank and tightened up all the stuff. Below is the pin out in case you do loose a wire marker, like I did. Good Luck.
Nov 20, 2008 | 2008 Harley Davidson FLTR Road Glide
Replace handle bars
Nov 10, 2008 | Harley Davidson FLTR Road Glide...
Baby Gear Logo
15 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
