Question about Maxi-Cosi Foray Trail Stroller
Cable Need to order two new cables for my Foray's handlebar length adjuster
  • Pepe Jul 25, 2013
    Same here, cannot find it anywhere! Might as well as head over to bike shop. These cables are very similar to bicycle cables.
  • Maxi-Cosi Master
  • 1,629 Answers
Hi
Could you please advise which country you're in?
Posted on Jul 27, 2013
Testimonial: "United States of America and I need the two cables, stat!"
My clutch engages almost all the way out of my clutch handle. How can I bring it closer to my handlebar??
try adjusting the length of the outer case by turning the end housing out more ( same idea as adjusting the hand brakes on a push bike )
the cable could be stretching and failing so consider the possibility of a new cable
Nov 18, 2015 | Motorcycles
Changed handle bars on my 1998 heritage and now the throttle isn't closing .
You need to adjust both throttle and return cables. They need to be the correct length and if you installed mini apes you likely also needed longer cables. Cables need to be adjusted so there is not binding and not rpm change when rotating handlebars fully each way with engine idling. If you do not know or cannot figure out how to adjust the cables etc make another post and ask.
May 30, 2014 | 2011 Harley Davidson FLSTC Heritage...
Motorcycle engine slipping wih new clutch plates and cable
Is the pressure plate (springs) ok? New discs will not work if they don't have enough pressure on them. Do you have any free movement of the clutch at the handlebars, before you feel pressure? Maybe you just need to adjust your clutch cable.
Feb 09, 2012 | Motorcycles
Need to know how to adjust the handle bar on a schwinn ranger 21sp
It doesn't go any higher if that's what you mean.
http://www.sheldonbrown.com/handsup.html
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
A reputable Bicycle Shop would have fit the bike to you before you took it home.
Sep 03, 2011 | Schwinn Frontier Series
How do I adjust the height of the handlebars on a Royce Union Aruba bike?
Aug 14, 2011 | Cycling
How do i adjust the height of the handlebar on Supercycle 2100 gsd
Aug 09, 2011 | Cycling
I just replaced my clutch cable, but now that I've put everything back together I have a problem. The bike will from neutral to first and back without the clutch lever pulled in. However it also...
Good news, you just need adjust the clutch cable..
Always order the part for your model and year when getting parts and make sure it matches in length with the old one. Note how much cable is sticking out of the housing.
Is it 3 1/2 inches or 4 inches or 2 inches. make sure the new one matches.
Put the new cable on with lots of slack.Slack at the adjuster, and slack at the handlebar adjuster
Now pull the lever in, it will be easy because of the slack.let it stay there.
It will stay against the grip.
As you tighten the cable adjustment down by the cover, you'll notice the clutch lever move out.
Once it reaches the top, stop adjusting and pull it in again.
Continue adjusting and pulling the lever until the lever springs back to the top.
You can feel resistence which is the clutches disengaging.
Make sure there is 1/8" free play when the lever springs back.
Now turn the clutch cable adjust on the handlebar outward, which will remove the rest of the slack.
Only leave 2mm slack on the lever.
Now start your bike up and it should work like new.
You want your clutch to disengage within the first 1/2" of pulling the lever in.
This ensures the clutches are definately disengaged by the time you get the lever pulled back to the grip when shifting.
If your clutches are slipping or dragging no matter how you adjust the cable then your clutches may need replaced.
But sounds to me like its just an adjustment.
Hope to be helpful
Big Al
Jul 25, 2011 | 1993 Yamaha FZR 600
THE CABLES INSIDE MY HANDLBAR HAVE SNAPPED CAN I GET NEW ONES OR GET THEM REPAIRED ??
Good Morning
The cable in the handlebar is not available as an individual item - to replace it you'll need the entire handlebar replaced.
If you are in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase; They can either order a replacement handlebar for you to fit, or they can send your chassis to our engineers to fit a replacement, under the warranty terms and conditions.
If you are in the UK and the product is over 2 years old or you do not have proof of purchase you can order a replacement handlebar to fit yourself or book in the chassis for chargeable inspection and repair work required by phoning the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. A replacement handlebar which will fit the 2007 model onwards is £50 plus £8 p+p. To book the unit in for the engineers to replace will be £60 and will include safety checks following repair work and courier delivery of the chassis back to your address. In addition to this you will need to make arrangements and cover costs for courier delivery of the product to our engineers.
If the product is a 2005 or 2006 model the current style handlebars do not fit straight on. In this instance the chassis will need to be sent to the engineers for them to provide replacement.
If you're not in the UK please visit www.quinny.com and select the country you're in, then use the "Contact Us" tab to be put in touch with the customer service department in your country.
Jun 13, 2011 | Quinny Buzz Three Wheel Stroller
I am changing the handlebars to 16" ape hangers, need the instrucitons to change the clutch cable and the throtle/idle cables
To change the throttle/idle cables, first you need to remove the fuel tanks so you can get to the carb/throttle body. Loosen the adjusters at the throttle grip on the handlebars. Remove the idle cable first and the remove the throttle cable from the carb/throttle body. Then take the two bolts out of the throttle grip housing halves and carefully seperate them. Remove the old cables from the twist grip. Reinstall new cables in the reverse procedure. Before starting the bike, make absolutely sure that the throttle cables work like they're supposed to and the carb/throttle body will close completely.
To remove the clutch cable, remove exhaust system or whatever might be in the way on the right side of the bike. You need to remove the right side transmission cover. Drain the transmission oil. Remove the chrome right side transmission cover. Disconnect the clutch cable from the clutch release mechanism. Screw the end of the clutch cable out of the cover and take the cable loose from the clutch lever on the handlebars. Reinstall in reverse order making sure you install a new O-ring on the cable at the transmission cover. Replace cover and refill transmission with oil. Reinstall anything else you had to take off.
Feb 15, 2010 | 2008 Harley Davidson FLHR Road king
Maxi-Cosi Foray Trail Stroller Logo
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
