Question about Refrigerators
Outside controls on door do not work
I changed the inside filter. My ice maker makes ice ok. The light on the outside of the door where you get the water and ice stays on all of the time. The outside functions do not work. The water, the ice, and the crushed ice functions do not work.I tried to shut off the power to see if it would reset, but it did not change. The light is still on. Thank You, Bob
    Sergeant:
  • 308 Answers
You need a UI control board
Posted on Jul 26, 2013
Joe_Rex
  • 114 Answers
SOURCE: no water or ice
ALWAYS CHECK FROM THE WATER SUPPLY LINE TO THE WATER SOLENOID VALVE ... TO ENSURE THAT YOU HAVE GOOD WATER FLOW ... IF WATER FLOW IS GOOD, SHUT "OFF" VALVE. THEN YOU CAN CHECK WATER SOLENOID VALVE STRAINER AND ORFICE TO SEE IF IT IS CLOGGED. (USUALLY LOCATED BEHIND FRIG.... INSIDE THE INLET SIDE OF THE VALVE THAT REQUIRES YOU OR SOMEONE TO REMOVE THE SUPPLY LINE BRASS NUT. (IN SOME CASES THE FITTINGS ARE NEOPREME) CREFULLY REMOVE THE STRAINER AND ORFICE ASSEMBLY ... IT IS SMALL !!! (CLEAN THEM THROUGHLLY). REPLACE ALL PARTS THE WAY YOU REMOVED THEM.... TO CHECK WATER SUPPLY SOLENOID OPERATION EASILY ... JUST USE A "METAL BUTTER KNIFE AND HOLD IT ABOUT 1/4" FROM THE TOP OF THE VALVE ... YOU SHOULD FEEL THE MAGNETIC PULL IF IT IS GOOD. LASTLY LOSEN THE NUT ON THE SIDE OF THE VALVE THAT LEADS INTO THE FRIG. TO CHECK FOR WATER FLOW. IF YOU HAVE WATER ... THEN THINK ABOUT CALLING A "LICENSED FACTORY-CERTIFIED COMPANY TO GET A "FLAT-RATE DIAGNOSTIC CHECK". UNFORTUNATELY THOUSANDAS OF CONSUMERS ARE BILKED BY SO CALLED FIX-IT-ALL HANDYMEN WHO LOOK TO REPLACE PARTS THAT CAN COST YOU HUNDREDS. NO WATER ??? NO ICE !!!
Posted on Apr 27, 2007
Krazytech
  • 725 Answers
SOURCE: Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Posted on Apr 05, 2008
  • 3422 Answers
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
SOURCE: Ice Maker Problem
sometimes the ice maker works and sometimes it does not work.
Posted on Mar 09, 2009
SOURCE: water dispenser not working
I had the same problem. Your water line is frozen. Turn off your freezer and the water line will unfreeze and it will work. You can see about putting in a heater on your water line. There have been mixed reviews on whether or not it works. The water line just froze again, so I may try the heater.
Posted on Aug 16, 2010
Turn on water light on outside of door
Can be faulty control panel causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Maytag Refrigerators
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Not making ice after changing filter.
Hi and welcome to FixYa I am Kelly.
A new filter can take several cycles of the ice maker to fill the filter up with water before. The average filter is around 30 oz and the average ice maker fill cycle is 3.2 oz. The new filter did not have any water in it. The water in the door has a resercoir so the air in the filter will still make the water work until you get air. Drain abour 3 tall glasses from the water in door. The ice maker should then work properly. The filter filters water for water in door (inside) and the ice maker so if you have water inside the door you should have ice UNLESS one of the inlet water valve solenoids has failed. Also make sure the Freezer door / light switch functions properly. The door switch is supposed to stop water and ice functions with the door open.
I would like to know if it starts making ice.
Thanks for choosing FixYa,
Kelly
Jul 26, 2011 | Jenn-Air JFC2089HE French Door...
Ge profile refrig - watrer dispenser does not deliver water. Ice maker works fine. What is wrong?
Water solenoid at the rear of the fridge has failed, there is two or three solenoids there, locate the one that does water feed to the door (not ice maker) and do a load test or just replace. Also make sure you dont have a filter safety cut-off, check filter cond and it is located perfectly in housing, check lines inside and outside fridge unit for obstructions. Good luck.
Feb 27, 2011 | Continental Freezer Wide...
I have a Kenmore side by side 26' model 596.50692000. The unit is cooling however, the lights in the freezer side and the dispenser for ice & water outside the lights do not work but the water...
in the past i have seen this happen when the ice ben is emoved and the drive impeller is not seated properly usually due to ice ect. Its a pain but take out the ben and see if the motor turns normally. you can hold the door switch closed by hand and have someone push the button for ice if the motor turns you have the problem i have said. If not your door switch is bad and needs to be replaced it controlls the power to the bulb and the ice maker motor. You can pop the door switch out with a flatblade screw driver but have a replacement on hand wire plug into the back of it the switch is an on off switch. Make sure you unplug the ref first electricity bites...
Aug 08, 2010 | Kenmore Refrigerators
FRS262GEB Side By side Not Making Ice
Typically when this problem occurs there is a clog of some sort between the filter and the ice maker. Disconnect the filter, stop your icemaker and take the fill line off. Blow compressed air from the filter side, until air blows freely. Reconnect all parts and turn unit on.
Aug 22, 2009 | Frigidaire FRS3R5EMB Side by Side...
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Changed filter, red light flashes, not making ice at all
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
