Question about Dryers
Whirlpool 6th sense dryer
What does the red rectangle with three bars in it mean on the display?
    Top Expert:
  • 12,223 Answers
You must read your owner manual, for ID, in section troubleshooting
God bless you
Posted on Jul 25, 2013
  • 46 Answers
SOURCE: Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
Posted on May 25, 2009
localwonder
  • 6784 Answers
SOURCE: our whirlpool 6th sense dryer model awz3413 will
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Posted on Jul 21, 2009
bozcro
  • 867 Answers
SOURCE: Whirlpool 6th sense dryer gets hot but is not
i think air vent is clogged. check the vent line, remove if you have to, but check outside vent on house wall first. may be even birds nest there.check hole where vent attaches to machine.-plz rate-bozcro
Posted on Sep 20, 2009
  • 77 Answers
SOURCE: HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Posted on Mar 20, 2010
heatman101
  • 43501 Answers
SOURCE: My whirlpool 6th sense dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
I put my 6th sense dryer on for 60 & when i turn it on it says 6 hrs.also can i buy a manual for it please
Can't help you with your first problem, but if you had just Googled Whirlpool 6th Sense Dryer you have found a wealth of information including a free manual. Check here:
http://www.whirlpool.com/-[WEL98HEBU]-1021441/WEL98HEBU/
Jul 10, 2016 | Dryers
Mar 19, 2010 | Whirlpool Dryers
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
May 25, 2009 | Dryers
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Dryers Logo
66 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
